Noise and pops when recording w Fast Track Ultra
I'm using a Fast Track Ultra with the lastest Win 8 drivers and DAW cubase 7 (64-bit). The card works great with Cubase, VSTi and the latency i quite low and the drivers are stable for playback and recording VSTi synths.
But when I record (synths, mic) through the Fast Track Ultra inputs I can hear som noise and pops in the recording. It's not so loud but you can definitely hear it. It doesn't matter what input port I'm using the noise/pops are there. I tried to change the buffer size but it makes no difference. I also tried to change the USB-cable and USB-port. No success. Any ideas? |
Re: Noise and pops when recording w Fast Track Ultra
Well...I will answer my own question. I did alot of "google research" and now my problem is solved.
I did two things to make the recording issue go away: 1) Reinstalled the drivers and actually downgraded to the second newest driver (6.1.8). 2) Removed my USB wifi adapter and plugged in a newer one. I think that this was the actual problem. Anyway. Now everyting is working great... |
Just stopping by here again...
After my last post I was actually still having problems with jitter och some drop outs. Turns out it was one of my synths causing a ground-loop disturbing the USB interface - I had too many synths on one socket (I think). I just moved the cable to another wall socket...problem solved...quiet...works great on win 10... |
Fast Track Ultra spdif - digital noise only | wallykissel | General Discussion | 3 | 03-04-2013 01:16 PM |
Recording on Fast Track 8R Ultra | twister | Pro Tools SE and Essential (Win) | 0 | 11-12-2012 08:24 AM |
Fast Track Ultra back ground noise | deanobeano | Windows | 0 | 10-31-2011 07:55 AM |
No sound after recording session? Fast track ultra 8r | andyv | Pro Tools M-Powered (Win) | 0 | 10-30-2010 01:44 AM |
Problems recording Guitar In PT 8 with Fast Track Ultra | smdrumz | Pro Tools M-Powered (Win) | 6 | 11-30-2009 07:23 PM |
