Mbox Mini Knob Gain problem
Hi There
I can't seem to find help for this....I appreciate any help at this point... So, I have a Mbox Mini 3 that I came with ProTools 8 LE and my microphone is ElectroVoice RE20 (Cardioid)- My PC runs on Windows 7. The problem - Unless I turn my Gain Knob all the way to the right, I almost don't hear anything. When I do finally reach the last part of the turn, sound pops in and I hear at MAX volume. Now, Everything is plugged in fine, Gain knob is NOT pulled out, Mic volume is in the middle, mix knob is in the middle...software works fine, Mic is tested and works, I even tried a different mic and a different cable...So, am I the only one with this problem. OR is this a KNOWN problem? Please help... Zach |
Re: Mbox Mini Knob Gain problem
What other mic did you try?
The RE20 is just like the SM7/7B it needs a lot of gain. Mics like that aren't designed for just any pre.
URBAN MUSIC- (Hip Hop and R&B) |
The other Mic I used was the AKG D5...it had more or less the same reaction... |
What type of mic would you suggest i use to test it?
Try a condenser
Hi Gremlin, I've tried tinkering with the headphones volume but its not the case...imagine that yopu hear nothing and then all of a sudden you hear 100%...and when I say 100%, you can hear the air move...meaning distortion...so I can't record.
Ski, I still need to try a condenser mic. |
Someone (technician) told me this might be a software conflict with my operating system...said he's heard about this issue with the the mboxes...does that sound logical to anyone?
I would get a condenser and they look at the gain settings in the mBox Control Console while testing it.
Did you ever determine the root cause to this problem? I purchased an mbox 3 yesterday and am having the exact same issue. No volume in the monitor headphones until turning the gain all the way up. I barely able to hear the mic until about 98% then it is too loud to record because of the distortion
This happens with my dynamic microphone and condenser mic on two different computers. I'm beginning to believe I got a defective unit. Wondering if you came to the same conclusion. |
Mbox Volume Knob 0dB Unity Gain | zenstone | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 06-01-2012 02:06 AM |
Mbox gain knob problem | unripevocal | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 08-05-2011 11:38 PM |
MBOX2 MINI Gain knob high rumble! | barismanco123 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 04-20-2011 05:26 PM |
Mbox 2 mini and mix knob | Greg555 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 01-03-2009 04:20 PM |
using outboard pre w/mbox - gain knob setting? | sgladm | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 8 | 09-11-2005 09:35 AM |
