Old 11-04-2007, 11:21 PM
aandina aandina is offline
Default Mbox 2 disappeared....
Hi.
Today I've launched PT LE but... ir doesn't see the Mbox 2. I've checked in the System prefs and I see it connected. Unfortunately the Digidesign Core audio manager, is running, but no Mbox 2 connected.
Help...
Does anyone have any idea?
Thanks in advance.
Using a Macbook pro.
Angelo Andina
Italy
Old 11-05-2007, 12:49 AM
Stiff Stiff is offline
Default Re: Mbox 2 disappeared....
I don't know if this is an issue with the Pro model, but on the regular MacBook you should use the USB port closest to you.
Daily news & reviews
www.ProToolerBlog.com
Old 11-07-2007, 02:45 AM
Hi.
I suppose the problem is that I've installed a new application. I'm referring to:
http://www.nch.com.au/golden/index.html
After having installed it... no way to see the Mbox 2. Tried to reinstall the Core audio, problem not solved.
How can I proceed? I'm getting lost...
Thanks in advance for you help.
Angelo Andina
Italy
Old 11-07-2007, 04:12 AM
Gary Nattrass Gary Nattrass is offline
Have you installed leopard if so this may be the problem.
Also if it is an intel macbook pro sometimes if there has been an update to the os system then pro tools loses the pre-binding script.
more details here:http://www.digidesign.com/index.cfm?...4&itemid=22904
Over 30 years in Broadcast Film and TV: www.HDProductionSolutions.com
Old 11-08-2007, 10:53 PM
Hi and thanks for you reply.
I've tried to install the Prebind repair but with non success. Are there any additional resources where I can try to fix this problem? I'm getting lost...
Thanks in advance for your extra help.
Regards
Angelo Andina
Italy
MBox External Disappeared bluestudio FireWire & USB Audio Interfaces (Win) 8 05-30-2013 08:38 AM
HD on Mac disappeared stevegalante Storage Subsystems 10 08-17-2012 01:51 AM
Mbox 3 disappeared from playback engines LaS Windows 0 05-10-2012 04:15 PM
Help: My 192 has disappeared! alanbuf macOS 1 01-03-2012 04:51 PM
Mbox 2 disappeared atchou 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 06-29-2009 08:58 PM
