#21
Re: Anyone Using the new M-Audio Project Mix I/O ?
is RCA the same as S/PDIF? The look the same but I could never figure out if they were compatible. I thought S/PDIF was digital or something.. but are you sure that adapter would work? Cuz that'd be just awesome!
#22
I suggest you go to the Technical Documents section and download a reference guide for M-Powered PT. Get a head start on the learning curve before you buy. |
#23
ohhhhh my bad, I didn't realize you could do that! That is awesome! Thank's, I guess I have lots of reading to do lol.
By the way, i've been using ProTools LE for about a year, I've just never used outboard effects before (all RTAS thus far). I was confused because the 002R has effects send/returns and the ProjectMix doesn't, but I understand now. So what I'm trying to say is that I'm not a complete noob, but there's definately plenty more to learn. |
#24
I find a new nugget most everyday. Good luck and let us know how the ProjectMix works out for you. Oh... S/PDIF uses RCA jacks, but it is a digital format, not analog. |
#25
[QUOTE]
So if you wanted to take an outboard Sonix Maximizer (analog?) and use TS cable w/ an adapter to plug it into the S/PDIF in.. That wouldn't work? |
#26
No... S/PDIF digital only.
You'll have to use analog In's and Outs. |
#27
does anybody know if you could use the 1/4" ins for effects while using the xlr ins for mics? for example - sonic maximizer outboard in line-1 with a mic in xlr-1, then set up tracks in Pro Tools with seperate tracks for effect and mic, so (ideally) you could use the effect across any track. Is anything like this possible, or is it a one-or-the-other situation..?
#28
No. You cannot have two inputs at the same time on the same line. You can use any of the other unused inputs for the maximizer, apply it to an Aux track, and Bus any/all tracks you wish to it.
Or, you could apply it to the Master fader to effect the entire mix. |
#29
#30
can I use M Audio Project Mix w/ PT 11? | JeffGT | Windows | 4 | 01-08-2014 06:32 AM |
M-Audio Project Mic I/O | Lyrical | Pro Tools M-Powered (Win) | 2 | 06-10-2007 01:09 PM |
M-Audio Project Mic I/O | Lyrical | Pro Tools M-Powered (Win) | 0 | 05-26-2007 02:48 PM |
PT M Audio 7.3.1 and Project Mix I/O | marcioguitar | Pro Tools M-Powered (Mac) | 2 | 03-28-2007 07:29 PM |
can m audio project mix be used with pt le | geefive | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 10-10-2006 10:09 PM |
