Old 05-17-2016, 09:56 AM
JanuS JanuS is offline
Default Dock iPad compatibility
Dear Avid,
Are the first iPad generations compatible with PT Dock?
Or is it only from iPad Air and up?
(I have an Ipad first gen, which I would like to use for the Dock..)
Old 05-17-2016, 10:41 AM
Righty27 Righty27 is offline
Default Re: Dock iPad compatibility
Hi JanuS - specifications suggest that iOS 8 is required, so that would rule out very early iPads ... which is a shame as I have an 'iPad Classic' (i.e. V1) which could otherwise be put to good use in this way :)
Old 05-17-2016, 02:22 PM
Thank you Righty27, and to answer my own question, I should have looked at the system requirements on the new Avid Dock page... It says:
iPad Air, iPad Air 2, iPad Pro (9.7-inch), iPad mini 2, iPad mini 3, iPad mini 4
* Please note that iPad Pro (12.9-inch) is not currently supported
Old 05-17-2016, 02:58 PM
alk3997 alk3997 is offline
One question I have is which of the above fit the Dock the best and line up the graphics with the Dock the best?
In other words, if you are buying a new iPad which is the best fit?
Andy
Old 05-17-2016, 04:10 PM
amolin amolin is offline
Andy
Air and Air 2.
Old 05-17-2016, 10:02 PM
Originally Posted by amolin View Post
Air and Air 2.
... although looks like these require a right-angle Lightning cable (see other thread) :)
Dock or iPad Pro SOUNDDECISION Avid S1, S3, Dock and Control App 1 05-16-2016 09:19 AM
Avid say that the Dock works standalone with an iPad john1192 Avid S1, S3, Dock and Control App 17 04-16-2016 03:45 PM
Dock with iPad mini LukeHoward Avid S1, S3, Dock and Control App 2 03-08-2016 03:00 AM
OWC's TB2 dock YYR123 General Discussion 3 11-19-2014 06:39 AM
