Re: Identical Crash threads....
I'm also getting this one, had it a couple of times so far, again during various tasks.
Thread 33 Crashed: 0 com.digidesign.framework.DAE 0x04017c08 FWAudioCallback + 184530 1 com.digidesign.framework.DAE 0x04018167 FWAudioCallback + 185905 2 com.digidesign.framework.DAE 0x04017ae8 FWAudioCallback + 184242 3 com.digidesign.framework.DAE 0x04018ce8 FWAudioCallback + 188850 4 com.digidesign.framework.DAE 0x0401871a FWAudioCallback + 187364 5 ...gn.framework.CoreFoundation 0x004f069e Sys_RawThreadTask::Run() + 36 6 ...gn.framework.CoreFoundation 0x0050f0fe Sys_RawThread:estroy(Sys_RawThread*&) + 246 7 ...n.framework.PlatformSupport 0x002f0c2a PSHardware_MatchDeviceInfo(TPSPCIDeviceInfo const*, TPSPCIDeviceInfo const*) + 12118 8 libSystem.B.dylib 0x937956f5 _pthread_start + 321 9 libSystem.B.dylib 0x937955b2 thread_start + 34 I've also had this very similar one, dunno if it's related or not: Thread 28 Crashed: 0 libSystem.B.dylib 0x93845dbe __semwait_signal_nocancel + 10 1 libSystem.B.dylib 0x93837c87 usleep$NOCANCEL$UNIX2003 + 61 2 libSystem.B.dylib 0x9385948b abort + 85 3 libstdc++.6.dylib 0x96028005 0x95fe0000 + 294917 4 libstdc++.6.dylib 0x9602610c __gxx_personality_v0 + 1108 5 libstdc++.6.dylib 0x9602614b std::terminate() + 29 6 libstdc++.6.dylib 0x96026261 __cxa_throw + 101 7 ...gn.framework.CoreFoundation 0x023067f3 Sys_MachExceptionHandler::Init() + 1449 8 com.digidesign.framework.DAE 0x030d1eb0 FWMidiCallback + 191528 9 com.digidesign.framework.DAE 0x030d2187 FWMidiCallback + 192255 10 com.digidesign.framework.DAE 0x030d368a FWMidiCallback + 197634 11 com.digidesign.framework.DAE 0x0304cf7e FicGetApplicationInterface + 159574 12 ...ple.CoreServices.CarbonCore 0x966c1463 PrivateMPEntryPoint + 56 13 libSystem.B.dylib 0x937956f5 _pthread_start + 321 14 libSystem.B.dylib 0x937955b2 thread_start + 34 Computer model and processor speed - MacPro Quad 2.66 OS version - OSX 10.5.5 Pro Tools version - 8.0 Amount of RAM installed - 5GB Any attached peripherals - Lacie FW HD and CD/DVD, MOTU micro express Number and type of drives installed - 4 internal SATA, various models, 1 Lacie D2 Quadra FW800 external attached at time of last crash. Which of the drive(s) are being used for recording and playback - Internal drives A concise list of the troubleshooting you've already tried - Trashed prefs, repaired permissions. Now going to turn off the Lacie(s) and see if I get it again. |
Hopefully someone can figure something out with this...it's very annoying.
Chris |
I agree, I had it about 8 times yesterday. Still getting it with all firewire peripherals off.
I just got this again. One thing I noticed is that I haven't had for a few days while tracking....now that I'm mixing and am using drumagog I got it again. Might just be coincidence I'm not sure.
Chris |
Can anyone experiencing this please post your entire crash log?
You can post it between tags here on the DUC. |
#16
Yes Chris, I've noticed this too, I only seem to get it during mixing, but I don't have drumagog so it can't be related to that.
Certainly I can post entire crash reports digi, but what do you mean by "you can post it between tags?" Apologies but we've only just switched to HD from Logic so I haven't visited these forums regularly until recently. |
#17
Try turning off the "use DSP cache" new and on the system usage window.
I've not been getting this crash since doing so. May or may not be the cause but fewer crashing is fine for me. PPC Dual 2.7, 6Gb, OS 10.5.5, PTHD 8 (cs1) |
#18
Just got it again. I'm not sure how to post the log here on the duc as it's too many characters.
I've copied it to a text document that can be download here.... http://www.greatwideopen.net/access1/DIGI/ Thanks, Chris |
#19
Have posted a couple of mine here, from different days and sessions:
http://download.madhat.co.uk/PTLogs.zip Hope it helps. |
#20
I've had this twice again so far today while mixing. One thing I noticed but I'm not positive is realted is that it seems to crash while playing back and then doing something that changes a graphic on the screen.
The first crash today happened while the song was playing and I tried to scroll the edit window further a head. The second happened while playing the song and selecting/hi-lighting a track in the mix window. Every time it happens the audio loops between 5 and 8 times, (swod while it's looping) and then it crashes. Just a couple of observations. Chris |
(12) 8.0.1 threads. (4) Legacy threads. Jeez!! | Sean Russell | Pro Tools TDM Systems (Mac) | 35 | 09-18-2009 07:59 AM |
Is 7.4.2 HD identical to 7.4.2pr HD? | CHD | Pro Tools TDM Systems (Mac) | 7 | 06-22-2008 01:58 AM |
Identical Unique IDs?? | Rizman | Pro Tools TDM Systems (Mac) | 0 | 05-04-2004 09:23 PM |
Mulitple identical icons | mrmxed | Pro Tools TDM Systems (Mac) | 9 | 09-15-2003 01:03 PM |
Mix cards identical for PC/Mac ? | James Thomson | Pro Tools TDM Systems (Mac) | 1 | 02-17-2003 09:24 AM |
