Old 06-21-2010, 03:55 AM
soundworx soundworx is offline
Default Messy session after automated Reconform
Just did a 3-reel reconform with Conformalizer. With all these extra edits and inserts, is there a "smart" way of getting rid of all the unwanted automation breakpoints? (erase breakpoints where there's no audio region or something)
It's really messy to look at and I can't imagine it being helpfull for the responiveness of the session.
Old 06-21-2010, 04:05 AM
Default Re: Messy session after automated Reconform
Select over break-points then hit X (only works on the automation parameter currently selected)
Other option: Select, then write to all enabled automation with a static setting.
Frank.
Old 06-21-2010, 05:56 AM
Reckless Erik Reckless Erik is offline
You could also try Control X which will glide all parameters in the selection and as a result clean up the look or,
Control delete which will delete all automation in the selection or,
Thin all, a new command in 8.0.4 which will thin all automation in the selection.
Be careful that you don't delete something that you shouldn't!!
Regards Nick
[email protected]
Newcomer Audio Post
MacBookPro 2.3GHz i7 16GB RAM OSX 10.15.7, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Mac M1 Studio Ultra 64GB RAM OSX 13.6, PT Ultimate 2023.12 HDn, MTRX Studio, 2x Avid S1, PT Dock...
Old 06-21-2010, 08:38 AM
jimlongo's Avatar
jimlongo jimlongo is offline
Command-option-/ will write a static set of all automation across a selection.
noise | jimlongo
Old 06-21-2010, 03:21 PM
Ray JB Ray JB is online now
option-apple-T (thin automation) works well to vape non-useful automation points
Old 06-22-2010, 03:31 AM
The Cargo Cult's Avatar
The Cargo Cult The Cargo Cult is offline
The Cargo Cult
I've often thought about adding an optional "automation cleanup" routine at the end of a conform run to tidy up that breakpoint debris.
if I did, which command would you guys prefer for it to call?
write to all?
clear all auto?
glide ?
cheers,
justin
Old 06-22-2010, 07:26 AM
bad jitter bad jitter is offline
I would always like to keep my existing automation after conform. "Problems" are all those new useless automation breakpoints, which don't actually affect automation at all. But IMO, it's not a big problem. Also, I think that it's Pro Tools that should have the "delete useless automation breakpoints" command after all.
Old 06-22-2010, 07:28 AM
I also pretty much ignore those break-points. I never noticed that they made the session slower. For me it´s only been more a "cosmetic" than a real issue since nothing is playing there anyway.
frank.
Old 06-22-2010, 10:50 AM
frank.
It is a cosmetic thing, I agree, haven't noticed any issues with performance yet, but I use a HD2 pretty much maxed out, so I have to be very organized to make that work. (low budget feature). And besides that, I hate faders clunking all over the place for no reason.
Speaking of faders; Anyone for a no preamps, 16/24 fader, Eucon enabled, integrated keyboard Digi Controlsurface? Where's the good news ;-)?
Old 06-22-2010, 02:20 PM
The Cargo Cult
the problem I have with leftover automation in those gap areas is that at some point I'm gonna fill the gap with audio and depending on how I do that, the automation in that area might get left behind. and it's usually a snap up to zero dB which I may not notice right away.
the other issue is that plugin automation breakpoints are only accurate to within a couple of frames so you might find your atmos EQ setting kicks in 2 frames after the scene starts simply because there's a chunk of "nothing" preceding it.
justin
HTML code is On
FCP to PT, reconform of cantar files? mr.armadillo Post - Surround - Video 13 04-18-2012 08:29 PM
Playing a PT8 session in PT9 - messy sounding gravol macOS 6 12-06-2011 06:23 PM
reconform from a new omf? Possible? agus Post - Surround - Video 3 03-27-2009 04:51 PM
Upgrading to XPP - Is it easy or messy? j20056 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 05-03-2002 10:09 PM
Softsynths Messy in PT JLEpperson MIDI 1 02-12-2002 05:37 PM
