Old 05-04-2004, 08:22 PM
Muxlow Muxlow is offline
Default Do empty tracks suck resources?
Do any of the following:
• Empty track, audio
• Empty track, MIDI
• Muted send
• Bypassed plug-in
...have an effect on CPU/Memory usage?
Mac G4 Dual 533
1.5g Ram
OS 10.2.8
Reason 2.5
ProTools LE 6.1
Digi001
Old 05-04-2004, 08:51 PM
Default Re: Do empty tracks suck resources?
Why don't you take a few minutes to run some tests?
Quad 2.5 G5, 4.5G RAM
Old 05-05-2004, 02:12 PM
mulderg mulderg is offline
I'm not certain about all the scenarios, but it is my understanding that a plug-in will still use the same resources if bypassed.
Regards
Old 05-05-2004, 04:46 PM
Chris Cavell Chris Cavell is offline
Yes, they do in fact use resources, unless the items mentioned are disabled instead of just muted/bypassed. Empty audio and midi tracks will eat very few resources, but still eat up an available audio or midi voice unless disabled. Same goes for sends. Bypassed plugs actually use the same amount of resources that they would use if not bypassed...if disabled, they use no resources.
Cavell Studios
Old 05-06-2004, 07:50 AM
How do you disable a plug-in without deleting it?
Mac G4 Dual 533
1.5g Ram
OS 10.2.8
Reason 2.5
ProTools LE 6.1
Digi001
Old 05-06-2004, 09:31 AM
Bluemoon Bluemoon is offline
Hold down Control and Command and then just click on the track, plug, etc., just do the same to reactivate.
Is this the blues I'm singing?
G5 2.5dual, 4Gb Ram 2x250gb HDs. Using PTLE 6.9 under OS10.3.8.
Empty MIDI tracks RoxyRiot Pro Tools 9 2 03-27-2012 09:55 PM
Where did empty gap between Tracks & Groups come from?!?! rossta1 Pro Tools 9 4 05-28-2011 12:55 PM
deactivated tracks still using resources?? phoenixblack Pro Tools TDM Systems (Mac) 7 08-08-2010 10:56 PM
cpu power -empty tracks jmallen 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 01-20-2005 07:30 AM
Removing empty tracks defretman 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 06-03-2003 01:03 AM
