Old 04-21-2004, 07:52 PM
Muxlow Muxlow is offline
Default Reamping with a PODxt Pro, monitoring question
I made the jump to POD land and so far, I'm pretty happy. One thing I don't quite understand though, regarding reamping...
I have the entire reamping process working, and it's a beautiful thing. But when you're laying down that initial track (the dry guitar signal), how do you monitor both the wet POD and the mix? You can listen to the mix on headphones or monitors, or you can listen to the POD via it's headphone jack, but the two systems are completely separate and you can't have the dry signal loop out of the mix, into the POD and then back into the mix. Right now, I'm just letting the mix play through the monitors while I listen to wet POD through it's headphone jack.
Is there a slicker way of doing this?
No guesses, either. I've chased enough geese today
Mac G4 Dual 533
1.5g Ram
OS 10.2.8
Reason 2.5
ProTools LE 6.1
Digi001
Old 04-22-2004, 10:08 AM
Default Re: Reamping with a PODxt Pro, monitoring question
^ bump
Gorilla, I know you can answer this!
Mac G4 Dual 533
1.5g Ram
OS 10.2.8
Reason 2.5
ProTools LE 6.1
Digi001
Old 04-22-2004, 10:30 AM
davetron5000 davetron5000 is offline
Run the output of both to a mixer and connect monitors to the mixer.
Or, run the dry signal and the wet signal to two different tracks and monitor (and record) both (throw out the wet signal if you want).
MacBook Pro Core Duo 1.83
2 Gig RAM
OS X 10.4.8
002R/PTLE 7.3.1
Old 04-22-2004, 10:52 AM
LSRdigital LSRdigital is offline
Yeah, what he said. Just send the dry signal digitally into PT one one track, and then you can send the wet analog signal into another PT track.
June 2004 PowerMac G5 Dual 2 GHz
8 GB RAM
MacOS 10.3.9/10.4.2
M-Audio Audiophile 192
PT M-Powered 6.8/7.0
Old 04-22-2004, 01:37 PM
losttimestudios losttimestudios is offline
Run dry signal (back of pod xt) into audio track and record it with mute on. Run the wet signals to aux tracks; or record the wet signals to audio tracks, too, in case you get the sound you are looking for on a take and don't have to reamp. Either way you wet signal in the cans when recording and have the dry signal available for later reamping.
reamping with amplitube metal - totally noob question mr shikadance Virtual Instruments 4 12-14-2009 08:41 PM
mbox micro/podxt question MrPrime69 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-03-2009 07:29 AM
Reamping w/002R X-Amp Question JCWarrior 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 08-27-2008 08:53 AM
QUESTION: Reamping guitars with the 002 dounfol 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 5 08-30-2006 10:24 AM
Difference between PODxt and PODxt pro...other than $300!! pedrohead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 06-09-2003 07:28 PM
