Old 04-20-2008, 11:06 PM
onebigtrip onebigtrip is offline
Default Lag when using virtual instrument...
Today i ran into a problem using Reason 4 with PT that i haven't had before. I have a pretty full production in Reason that i want to add vocals too, but when i play the song through PT, Reason lags on every down beat. in other words, i have a 4/4 beat going, and when i come around to the first beat again, it kind of just lags for a split second - so the whole song is completely unfluid.
i use Reason often with PT to juice things up with synths and drums samples etc and have never had a problem with lag when sequencing everything in Reason and running it through an instrument track in PT.
my first instinct was that my computer was overloaded, but i find that highly unlikely as i have plenty of RAM and a dual-core 3 GHZ processor, and the CPU meter says im barely using anything.
this is preventing me from finishing my track! i just bought reason 4 and havent used it much with protools yet, so im wondering if protools 7.1 and reason 4 are having trouble getting along...
any ideas or clues would be much appreciated!
Old 04-21-2008, 03:17 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Default Re: Lag when using virtual instrument...
Are u trackin in reason or in PT...I've neva had any probs but I've ONLY tracked in PT using Rewire of course...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 04-21-2008, 03:36 PM
Tracking in PT using ReWire
Old 04-21-2008, 04:08 PM
U hav everything quantitized?...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
Old 04-22-2008, 10:47 AM
timebandit timebandit is offline
I experienced a similar problem only once. I had a rather large PT session and was using sounds from Reason. At that time I was using MIDI tracks in PT to trigger the devices in Reason. After a certain point there was a very slight timing lag coming from the Reason devices. I found in that case that the timing lag went away when I exported the MIDI tracks from PT and loaded them into Reason. In other words I was using the Reason sequencer to trigger the Reason sounds. I have worked both ways (using PT or Reason to sequence) many times since then and never experienced another similar problem. I don't know why that would be - maybe something to do with Rewire throughput priority? But it might help you to try that - at least to get the session done!
Tom
Tom Lynn
my music:
www.tomlynnmusic.com
other people's music:
www.headphonomenon.com
Pro Tools 11 - virtual instrument ysound Pro Tools 11 6 09-11-2013 07:36 AM
PT HD 10 Virtual Instrument Installer petesteen Pro Tools 10 1 03-22-2012 04:51 PM
Virtual Instrument help! madgt621 Virtual Instruments 2 04-06-2010 05:57 AM
Virtual Instrument Track marcioguitar 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 01-09-2009 07:04 PM
Virtual Instrument with a USB Keyboard? mightysphinx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-29-2008 09:37 AM
