Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools | First Discussion
Old 09-14-2020, 09:51 PM
Mahieu Mahieu is offline
Default Re: PTF still crashes
Originally Posted by junkgear View Post
You shouldn’t need Asio4all since Focusrite should have an ASIO driver for your interface.
I would uninstall Asio4all.
Make you you download and install the latest driver for your interface from Focusrite.
Reboot.
Next make sure Windows isn’t using the Focusrite as it’s default sound device.
One other thing you can try is deleting the PTF preferences, which basically clears any stored settings from earlier attempts at running PTF and starts from scratch. To do so, do the following:
1. Close Pro Tools.
2. Hold the Windows key on your keyboard and press R.
3. When the Run window appears, type %appdata% and press OK.
4. Open the Avid folder, and delete the Pro Tools First folder.
5. Restart your computer and launch Pro Tools.
Hopefully this will get you to the Playback Engine so you can select the Focusrite.
I don't use asio4all
I have already tested everything you are suggesting
It still crashes
My guess is that the problem is somewhere in the realtek audio driver (strange noises from the pc speakers during initialization before it crashes).
Please explore this hypothesis. How to test it with realtek engineers?
Thank you for your help.
Old 09-15-2020, 08:15 AM
JoelG's Avatar
JoelG JoelG is offline
Are you selecting your Focusrite as your audio device? If so, the Realtek shouldn't have anything to do with it.
Make sure you've selected it in the Playback Engine: http://akmedia.digidesign.com/suppor...irst_85131.pdf
Joel
Jam Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2020 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
Old 09-16-2020, 11:29 PM
It's just impossible to deactivate Realtek.
What ever I do, it still appears in Protools and makes it crash.
I just cannot understand nobody cares about it !
Anyway I have switched to another DAW, I cannot wait.
Pro Tools 12 crashes and crashes... Phantobias Pro Tools 12 12 09-15-2015 11:08 AM
PT Crashes and crashes again... Help needed! heabow macOS 5 01-23-2015 02:44 AM
all My Crashes rpossum Pro Tools 11 3 02-04-2014 11:13 PM
6.0.1 crashes w/ 10.4.2 rrood 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 07-26-2005 04:39 AM
LE 6.2.3 crashes @ least twice a day rtcstudio 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 04-06-2004 10:05 PM
