Old 08-31-2020, 12:37 PM
Aster Aster is offline
Default Recording midi tracks from Fantom G sequencer
Hi , I am having problems recording / replicating the individual midi tracks from my Fantom G into PT 11. All the midi tracks record on to one channel despite my routing /selecting the right midi channel. Ideally would like to route them individually (1 midi track per FANTOM G midi track) and record at once ? Any Fantom users out there that maybe able to help or users that record externally sequenced midi tracks to PT . I don not really want to export midi tracks from FG and then import to PT.
Old 08-31-2020, 01:25 PM
Top Jimmy's Avatar
Default Re: Recording midi tracks from Fantom G sequencer
Somehow the routing isn’t correct. If each sequencer track is routed to a unique midi channel, and each track in Pro Tools is set to only input a unique midi channel, then you will be able to transfer up to 16 individual midi tracks at once. Somewhere a setting is set to Omni or All when it shouldn’t be.
James Cadwallader
Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.4.
Pro Tools HD Native 2020.3, Focusrite Red 8Pre, Mbox 3 (Mac)
Pro Tools 11.3.2, Mbox2 (Win 7)
Old 09-01-2020, 02:53 AM
The Fantom G has 16 midi channels. I create a midi track select input Fantom G channel 1 in PT , in Fantom G channel 1 is the piano midi part. When i record it continues to record all midi parts on the same channel. Is there a global setting (PT or in the Fantom G) i need to enable or change something with my routing ?
Old 09-12-2020, 01:32 PM
I'd start by reading the Fantom manual to see if there is a way to export the midi files onto a USB stick(or over USB to your computer).
Old 09-12-2020, 05:20 PM
Southsidemusic's Avatar
Look for a setting on the Roland called ”Local On/OFF” and set that to Local OFF and you should be good
Best Regards
Christopher
South Side Music Group
WEBHOME
Pro Tools and Roland Fantom midi recording theman1 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 12-17-2007 01:30 PM
Recording Midi from External sequencer 6figgas 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 7 02-13-2006 01:19 PM
Problems Recording MIDI from an External Sequencer RMW 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 12-05-2005 11:17 AM
PT midi tracks or reason sequencer? deejfro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 03-25-2005 11:23 AM
Transfering note data from a sequencer to the sequencer of the digi 001 sequencer? MichaelK 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 11-05-2000 12:29 AM
