Pro Tools 9.0.5 crashing just after startup
Dear All,
I have tried everything, trash preferences etc. But ProTools 9.0.5 will constantly crash after startup, right after having scanned all the plugins and be ready to start... I am running OSX 10.6.7. Needless to say I had to downgrade to 9.0.3 for the time being ! Thanks, |
Re: Pro Tools 9.0.5 crashing just after startup
All plug-ins up to date?
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
Move all your plugins to a temporary folder and add them back one by one, starting and restarting Pro Tools with each one. If you have a lot of plugins you can take them and in chunks to narrow down which plugin it might be causing the problem.
Why do I immediately suggest this? Because it happened to me. The problem turned out to be my Flux plugins. Good luck. |
Many thanks for this.
Does that mean that even if my plugins are up to date, they are not necessarily compatible with 9.0.5 ? If this is the case, I'd rather wait ! ) |
Are you using any plug-ins from Fluxhome.com? I'm using TRAX & HEar, and 9.0.5 will not finish launching with those. I just tried their latest versions (1.1.9) this morning with no luck so went back to 9.0.3 for the 2nd time now.
Yes indeed !
Oh well, I guess I will just wait for 9.0.5 until this is solved ! Thanks for the heads up David |
Hey Guys,
Had the same issue too upgrading to 9.0.5 - I removed my flux pure compressor and it started up no worries. Thanks!
Intel Imac 2.33 Ghz 2 duo 2gigram, macbook 1.83ghz intel core duo 512ram, Mbox Pro, Alesis m1 active mk2, korg microKontrol, |
I had the same issue. Turned out it was Vocalign Pro causing it. Moved it to the temp folder, had no issues since. 9 times out of 10 when Pro Tools is crashing during startup, it's a plugin related issue.
I removed all my plugs and it still crashes. Anyone know how to trash preferences in LION? The pre-lion directions state "user -> your name -> library". But in Lion under "User -> your name" there is no "library" folder anymore. Any one figure this out yet?
I have noticed a crash at startup when core audio is already open.
Have you tried opening PT first after making sure no other audio app is using core audio? Also, Apple hid the ~/Library folders in Lion. If you care to experiment type this into terminal to unhide that folder: chflags nohidden ~/Library Seemed to help for me on startup for some plugins. DIsclaimer: don't do it if you are unsure or have work to do. FWIW YMMV are always appropriate acronyms and this is after all a beta ... |
Pro Tools 11.1 and 10.3.8 crashing on startup. | spoljar | Getting Started | 1 | 01-17-2014 11:59 PM |
Pro Tools 11 Crashing on startup | grum | macOS | 4 | 01-07-2014 10:45 AM |
Pro Tools 10.3.7 crashing on startup | kaiwelch | macOS | 10 | 11-24-2013 01:21 PM |
Pro Tools 8 crashing on startup | Count Validus | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 01-13-2009 11:16 PM |
Pro Tools crashing at startup | Jóhannes Bjarnason | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 12-10-2006 06:04 AM |
