WLM meter setup?
Hi. I'm supposed to deliver a mix according to these specs:
-20 lkfs -1 dbtp How do i set up waves wlm meter to make sure my levels are correct? Thanks:) |
Re: WLM meter setup?
-paul. @produceNewMedia |
-20 lkfs
-1 dbtp Well, i found out i can change the "momentary scale" to LKFS instead of LUFS. Great. But according to the post above, LUFS is the same as KLFS? So when i finished watching my material, it should land on -20 LKFS and have a max peak of -1 dbtp? What about the "method" button? (in the lower left corner) What should it be switched to? EBU, LM1 or Dial? ITU, LEQ, and what wehigting? Thanks Tak Last edited by the19thbear; 05-30-2017 at 01:45 AM. |
Don't worry, LKFS and LUFS are the same.
Method - EBU Weighting - BS1770 Target -20 Short Term Max -18 Short Term Min -23 That will give you a window of +2 and -3 Enable the True Peak Limiter and set to -1dBTP That should do it. If you want to learn more about loudness and loudness metering then follow my series on Pro Tools Expert. Hope that helps... Mike |
came on here to ask some similiar questions ?
what should the short term reading max out at if I am mixing to -23LUFS? I have a show I am doing now - usually I get specs with a +/- 2 on a 24 LUFS show. but this one the specs just say average 23 LUFS I've only ever worked to loudness meters on 'talkie' drama stuff with little action - I never had a QC knock back - but I never let it go "over" for even a fraction of a second but I am struggling now with an action animation. seems to want to push over all the time!! if I am in - it doesnt seem to have any impact
2018 i7 3.6 GHz 6 core mac mini running monterey 12.6.2 - 32Gig RAM 512 Gb SSD drive Focusrite Saffire PRO 40 Ultimate 2022 10 / HD Avid MC Mix / MC Control |
MIDI SETUP takes long to SETUP and doesnt SETUP | DartagnanSosa87 | MIDI | 3 | 01-28-2013 12:02 PM |
why external vu meter/ plug-in vu meter differ? | sjtae | macOS | 8 | 06-06-2012 05:50 PM |
Inserts affecting send meter but not channel meter? | Kbrinson85 | Windows | 1 | 05-01-2012 07:00 AM |
Solo Mute, and meter setup questions. | realizment | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 07-22-2010 12:03 PM |
PTHD8 cpu meter vs task manager cpu meter | MEAT | Pro Tools TDM Systems (Win) | 5 | 01-02-2009 05:17 AM |
