Midi is still playing from a track I made inactive
Hi
Im trying to print a new instrument part I just recorded using Kontakt 5 full version. As I go to dump this part down on to another track. Midi is still playing an instrument part from another track I created using Kontakt 5 full version. I even made the other track inactive its still playing the part from the inactive track thru the master track Im trying to dump to another track in pro tools 10.3.3 I have windows 7 pro 18 gigs of ram i7 processor 950 @ 3.07 Ghz 64bit service pack 1 Mbox pro 2 Rosetta 200 Please help Merry Christmas |
Re: Midi is still playing from a track I made inactive
So you're using a separate MIDI track and an instrument track? Have you tried just muting the MIDI track?
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Midi tracks cannot be disabled, just muted (which is only a term, because midi itself is not audio and has not sound at all - muting it just makes it stop sending data). Instrument tracks CAN be disabled and/or muted.
HTH Francisco
The audio world is full of (mainly very expensive) placebos. Windows 10 Pro 64 Bit Pro Tools Ultimate (perpetual with active updates/support plan) RME Fireface 802, Focusrite Clarett+ Octopre, Eleven Rack (ERXP) Monitors: Yamaha MSP7 and Yamaha HS8S Asus RoG Maximus Hero Z790 (in a 4U slidable rack mount! ) Intel Core i9-13900k 5.4 Ghz (16 cores / 32 threads) 128 GB RAM G.Skill DDR5 6000 MHz (4 modules 32GB each) Boot disk: Samsung 980 Pro M.2 2TB Media disks: 2 x Samsung 980 Pro M.2 2TB in RAID 0 for current work, 2 x Seagate Exos X20 20TB mirrored for archive and backup Video: PNY/Nvidia RTX 3080 TI with a single 4K display Dell U3223QE 32'' |
Yes, and if you're using a separate MIDI and Instrument track, and disable the Instrument track, it's possible that the MIDI track is still sending data to an Instrument track. You can either mute the MIDI track, or set the MIDI track to transmit on a single channel, so that it doesn't trigger a VI set to receive on All channels.
Make sure you have the channels correct on the midi track in out so midi on channel one goes to 1 in and 2 goes to 2 etc.
Create a MIDI track for kontakt channel 1. Don't have any data on the Kontakt VI track. Move the clips to the midi track, channel 1 I used to just let channel 1 data play on the VI but i always ran into this type of problem when using multi-channel instruments.
Dave Cournoyer-guitarist-project studio Mac Mini late 2012, i7, Sierra 16GB PT10.3.10HD PT12.5.2 Apogee Mini-Me firewire. |
Yes, you can have multiple instruments in Kontakt triggered by multiple MIDI tracks, but it's easy to set up as long as you keep your MIDI channels straight.
All plugs made inactive | Pehja | Pro Tools 11 | 2 | 02-27-2014 01:05 PM |
Inactive Instrument track still playing MIDI?? Bug? | ilovemyssl | macOS | 3 | 12-15-2010 09:22 PM |
Structure Audio Output playing even though track is Inactive | filosofem | Virtual Instruments | 1 | 10-08-2007 08:22 PM |
The following plugins were made inactive they could not be.. | RuffJazzRecords | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 07-18-2007 09:26 AM |
10.2.6/9.2.2 switch : MIDI devices made inactive | stevegalante | Pro Tools TDM Systems (Mac) | 3 | 09-25-2003 08:53 AM |
