Old 02-12-2021, 02:08 AM
Guy McDude Guy McDude is offline
Default Strange Graphic Bug in PT 10.3.6
Hi Guys,
Im trying to help a friend who's experiencing a graphic bug on his LE rig.
It seems to be affecting drop down menus, and "mis-aligning" the edit screen. I recall seeing this a while back, but cant recall the cause or fix.
This is a new occurrence since updating OS.
Trashing prefs did not help.
resizing track heights helped momentarily, as did saving and reopening.
any help would be greatly appreciated.
thanks!
rig specs:
IMac 27" mid 2011
20 gb ram
10.13.6 OS
MBox Pro interface
with most current driver
PT 10.3.6
Best,
Sean
Sean McDonald
Red Medicine Recording LLC
Sofa King Music Services
http://www.seanmcdonald.com
Old 02-12-2021, 02:13 AM
Default Re: Strange Graphic Bug in PT 10.3.6
PT 10 is not supported on your OS, and while it usually does not mean "not working" in this case you are dead in the water if you use anything later than 10.9.5
Compatibility info here.
Old 02-12-2021, 08:47 AM
Ben Jenssen's Avatar
It's a well known thing, PT10 on Yosemity and up - graphics problem with menus, discussed here plenty all those years ago. You either roll back to 10.8 or .9, or you upgrade to a PT version that supports High Sierra.
Old 02-12-2021, 10:54 PM
Thanks.
yes, checked the compatibility list, was just hoping to limp through until I could get him set up with a current, compliant PT version.
As other than the graphic bug, the sessions seemed fine.
thanks guys!
Best,
Sean
Sean McDonald
Strange Wav Graphic 12.4 Stys64 Pro Tools 12 4 06-29-2017 05:00 AM
Strange (graphic?) bug with PTHD10 handklang macOS 2 01-10-2012 03:09 PM
strange graphic on edit page boynigel macOS 5 10-30-2011 06:21 AM
Strange graphic anomalies in Protools 8.0.3 czorro 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 03-25-2010 03:42 AM
Strange waveform graphic steve0916 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 02-13-2003 08:52 PM
