Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Closed Thread
Old 02-07-2021, 02:20 PM
table17 table17 is offline
Default Carbon internal talkback distored
The quality of the talkback system on my Carbon seems wayyy off, in a bad way. Does the talkback system sound "okay" to anyone else?
For me, the amount of cooling-fan noise from inside the Carbon makes the talkback nearly unusable. But worse, and with gain in Hardware Setup set to lowest setting of 0dB, the system is quick to distort. If I talk with any amount of extra volume in my voice, about 1 foot away from the unit, it's overdrive city.
I've tried to test this on the Carbon's internal headphone amps, also routed outputs to external headphone distribution amps. All results are sub-par, to say the least.
Old 02-08-2021, 05:31 AM
LFO LFO is offline
Default Re: Carbon internal talkback system - not great results here
Hi, well I quickly try the internal Talkback on my Carbon and could hear as you the noise you're talking about.I didn't realise it was the fan but of course it makes sense) in fact I thought I was doing something improperly and having no time to investigate I just decided to see later.....Didn't notice distortion on mine however.Anyway if it's normal behaviour, well I'm afraid this talkback is unusable.....
Old 02-08-2021, 11:42 AM
Cowboy Bob's Avatar
Cowboy Bob Cowboy Bob is online now
While I agree it ain't great, I use it strictly as a talk back.
That said, for my usage, I just simply insert Dyn3 gate, and I have no issues. Yes there is fan noise but the gate helps with that, and I've experimented with how much TB to send to the talent.
Also I have the gain set about 24.
"If the grass looks greener on the other side of the fence, well, it is likely due to the amount of manure being spread on that side of the fence." Cowboy Bob
Squaw Creek Road Studio
Bob
Pro Tools Ultimate (2024.3.1)| Pro Tools Carbon | Sibelius Ultimate (2024.3.1)
M2 Max Mac Studio w/64GB RAM | 1TB SSD | Mac OS 14.4.1| (Main Rig) |
3.6GHz 8-core 9th-generation Intel Core i9 processor iMac w/40GB RAM | 1TB SSD | macOS Ventura 13.3.1 |
Avid Eleven Rack ERXP | Focusrite Clarett 8Pre X |
Old 02-08-2021, 03:00 PM
Today I got a reply from Avid - wow - great service! Someone at Avid Support saw this DUC post and emailed me.
So, the distortion I was experiencing is a known firmware issue. I rolled back PT from 2020.12 to 2020.11, reset firmware, and the mic levels are more realistic, not distorting anymore in normal use. I'll work in PT 2020.11 until next version rolls out.
For the fan noise, okay, I'll try a gate & finesse sends/volumes to talent. Thanks for that tip, Bob.
I also tried Waves x-noise, but that puts the talkback in 'native' mode with about 100ms delay. Waves z-noise introduced wayyy too much latency to be useful in a realtime use case. I'm going to try a demo of McDSP NR800 Noise Reduction Processor in AAX DSP mode & report back. Any other known/good noise reduction AAX DSP plugs out there?
Sure would be AWESOME if we could use an external microphone in the switchable/dimmable talkback system. I did try to use my own mic into input 24 (via adat), but that doesn't make use of switchable/dimmable functions that the talkback system utilizes.
Carbon / Mac Trashcan / Control 24
Old 02-08-2021, 03:47 PM
jeffro's Avatar
jeffro jeffro is offline
Glad to see that CS got back to you already! Had you logged a support case for this?
linkedin
Old 02-08-2021, 03:52 PM
Cowboy Bob's Avatar
Not to hijack this thread, but I’ll tell ya what, it sure seems that Carbon is getting a lot of visibility with CS and the development team members.
Kudos to y’all for that.
Bob
Old 02-09-2021, 04:02 PM
MCorbin's Avatar
MCorbin MCorbin is offline
Shoot, I think myself or Kyle have spoken with all of you at one point or another!
Jeffro, yes, we have a case for table17.
Thank you all for your passion & your patience.
m
Mark Corbin
Sr Principal Product Manager
Professional Audio Systems
For immediate assistance:
Pro Tools & Eucon Surfaces - +1 888-456-3444
Venue Support - +1 978-275-2557
Find out how to create, manage, and edit cases online now HERE
It's fast, easy, and effective!
Old 02-09-2021, 04:54 PM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Hello Everyone,
To follow up on this, we've recently discovered an issue with Talkback mic distortion on some units. We're working on a fix for this in the next Pro Tools release. In the meantime, please contact support for assistance if you haven't done so already. Thanks.
avid.com/learn-and-support/contact-audio-and-music-support
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 02-09-2021, 07:23 PM
yes, thanks, I have a ticket started. Firmware has helped with the distortion/level concerns. Fan noise... https://duc.avid.com/showthread.php?t=418957
Closed Thread
Carbon Talkback different DAW diogomusique Pro Tools | Carbon 4 10-19-2021 09:27 AM
Internal Talkback mic how to set it up Amr Mahmoud ICON & C|24 2 11-06-2008 04:43 PM
D-Command (Internal Talkback) Craig Timmis ICON & C|24 8 12-04-2007 01:09 AM
Setting up Internal Talkback Mic PTGuy ICON & C|24 6 08-28-2006 05:25 PM
