Old 02-07-2021, 03:45 AM
acmost acmost is offline
Default PTHD Dithering & Not Dithering...files NULL?
Greetings,
I have a 48_24 Mastering Session set up in PT HD10...bouncing down to 44_16.
I Bounce down without using a Dither Plug to 44_16.
I Bounce down using the POW(Type 2)Plug to 44_16
The two 44_16 interleaved WAV files are nulling.
Should this be happening?
TIA!!!
Old 02-10-2021, 07:47 AM
Default Re: PTHD Dithering & Not Dithering...files NULL?
They most likely are not nulling completely, only to the extent that the difference is tough to hear. When going from 24 bit to 16 bit, Dither SHOULD be used, While it won't change the overall sound, it will affect very low-level stuff, like reverb trails. The way to hear the difference might require you to crank the volume way up, and that can be dangerous for a few reasons(like accidentally trashing your speakers or your hearing) so my best advice is to trust the experts(not referring to me) and use Dither when its called for. You should also consider that not everybody has the perception of hearing detail of the next person. I have a friend that hears 100 shades where I hear 10
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 02-10-2021, 10:16 AM
Bob Olhsson's Avatar
Bob Olhsson Bob Olhsson is offline
PT HD10 requires that the dithered mixer be installed in addition to a 16-bit output plug-in. Without it, every single plug-in will be causing truncation distortion which can mask the low-level detail and reduce the effect of dither.
Bob's room 615 562-4346
Interview
Artists are the gatekeepers of truth! - Paul Robeson
Dithering... DJ Hellfire Tips & Tricks 12 11-07-2016 08:44 AM
Dithering in PT martthie_08 Pro Tools HDX & HD Native Systems (Mac) 7 03-25-2015 01:55 AM
why no dithering option on "export regions as files"? digidesigner Pro Tools TDM Systems (Mac) 5 03-15-2009 10:43 AM
Export 24 bit files to a 16 bit session same as dithering? Forrest77 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 03-06-2003 11:39 AM
Dithering Bretto Tips & Tricks 15 03-17-2000 12:20 AM
