Old 01-08-2021, 09:41 AM
larsongs larsongs is offline
Default how to create more Inserts on Channels & Master Fader?
I've seen a YouTube on this.. I thought I saved it in my Library but it's not there? I spent a couple hours last night & this morning trying to find it..
Do any of you have it or would uoi kindly post the method??
Thanks
Old 01-08-2021, 11:11 AM
Ben Jenssen's Avatar
Default Re: how to create more Inserts on Channels & Master Fader?
I don't have a link to a video, but I guess you're talking about routing a track via an aux track and thereby getting access to its inserts, increasing the number of inserts available to that signal to twenty. That's the only way, I think.
Life-long audio enthusiast and small studio owner. Retired.
Mac Mini 2018, six core i5 3.0 gHz, 32 gb RAM.
Focusrite Scarlett 2i2 3rd gen, Dynaudio BM6's, Command 8 and iPad w/Avid Control.
Pro Tools 2020.11, Mac OS 10.15.7.
Old 01-08-2021, 04:04 PM
The Weed's Avatar
The Weed The Weed is offline
You get 10 inserts per track, split 1-5 and 6-10. Are you not seeing them or do you want more than 10?
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 01-08-2021, 04:15 PM
Indeed, just run thru an AUX on the way to the master. Having said that, if you need more than 10 inserts on a mix, you're probably not mixing right
Gigabyte X79/intel i7 3930K, 32GB RAM, Presonus Studio 1810C
I started in this business with nothing..........and I have most of it left
Old 01-09-2021, 08:55 AM
crizdee's Avatar
crizdee crizdee is offline
Inserts are setup in the I/O page. Create a stereo insert then you can create mono sub paths as inserts. BUT if you are trying to place a mono insert on a stereo track then you'll have to use the methods above by routing to a mono aux or track and insert mono on that.
Chris
Producer, Engineer,
www.ukmastering.com
Old 01-10-2021, 03:27 PM
Originally Posted by crizdee View Post
Chris
This is accurate for hardware inserts. I suspect the OP wants to use more than 10 plugins. Plus, a single hardware insert could easily route thru several hardware units
Old 01-18-2021, 10:28 PM
Got it.. Found the I/O & got more Inserts..
Thanks
D-Command Master fader stuck in Inserts mode Jambroch ICON & C|24 2 12-17-2012 12:23 PM
Master Fader Inserts richardlewisx macOS 11 11-25-2011 06:39 AM
DIGI: Will it ever be possible to implement Pre-Fader Inserts on the Master Fader? Ricky Cobble Pro Tools TDM Systems (Mac) 5 05-05-2003 04:47 AM
Inserts on Master Fader SPDIF 7thheaven 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 04-03-2002 04:33 AM
Master inserts are post-fader? Was: L1+ on Master = clipping s2n Pro Tools TDM Systems (Mac) 10 11-20-2001 07:41 AM
