Old 07-21-2017, 05:06 PM
mfranken's Avatar
mfranken mfranken is offline
Sounds In Sync
Default EdiLoad v3.4 update released with support for UHD and new WAV File list window
Just released a new update for our sound-post workflow app EdiLoad. With v3.4 you can now...
  • Process Hi Frame Rate edit lists to support UHD workflows
    • Load, compare, re-conform sessions and export Hi Frame Rate EDLs (47.952 FPS -> 60 FPS DF)
    • Convert Hi Frame Rate lists to equivalent Lo Frame Rate
  • Updated Compare Window - Load Settings
    • Can now select which track(s) to load from EDLs. V All, V1, A All, A1
  • Added WAV File List window
    • Export WAV files as a Pro Tools session with files spotted to timestamp
    • Load location WAV files to inspect metadata, find duplicate files and export data as a text file
  • Added Create Scene Change window
    • Process edit list and export a Pro Tools session within a single window
    • Load scene descriptions directly from PDF shooting scripts or text files
    • See the demo video here
  • Added option to import EDL data from MS Excel files and TAB-delimited text files
  • Added option to export edit lists from main window as MS Excel file
  • During EDL load into main window
    • Added checkbox 'Ignore Source Timecodes' to copy Destination TCs to Source TCs on import. Select this when creating Picture Cut or Scene Change tracks from EDLs that contain multi-frame rate sources
  • Updated EDL load code to load EDL-X 'Single List' EDLs that contain multiple video tracks in a single EDL
See the 'EdiLoad v3.4 New Features' video here
Regards,
Mark
Mark Franken, MPSE
Dialogue editor/supervisor IMDb
Creator of 'EDI' applications for sound post editors
www.soundsinsync.com
Old 07-22-2017, 03:09 AM
JWalkerPostAudio JWalkerPostAudio is offline
Default Re: EdiLoad v3.4 update released with support for UHD and new WAV File list window
Great stuff. Thanks Mark!
-Justin
Justin Walker
HTML code is On
Purchased Annual plugin support plan just released? koka Pro Tools 12 3 09-17-2015 03:40 PM
EdiLoad v3 released mfranken Post - Surround - Video 2 03-09-2015 09:27 AM
View-Other displays-track list and regions list, only from edit window? crizdee Pro Tools TDM Systems (Mac) 0 02-27-2009 10:46 AM
Window Configurations List window stevedresser83 Tips & Tricks 1 09-26-2008 01:32 PM
Sampletank 2.03 update now released. IK_Jason 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 01-28-2004 11:41 AM
