Having problems using the internal talkback mic on the DCommand for talkback over Source-Connect. Within the xmon, is there an easy way of routing the TB (a bit like you do with the Assign TB button for headphones mixes) to an aux in the mixer which I can then send to the Source-Connect feed along with the mix? Or is my only option hooking up a physical cable output into a spare line input on the 192 and routing it that way? Thanks |
Yes, you need a physical cable.
James Cadwallader Hackintosh - Gigabyte Z77X-UP5TH, Intel Core i7-3770K, 32GB 1600Mhz DDR3, 2x SATA 6Gb/s 240GB SSD, 3x SATA 6Gb/s 1TB HDD, 1x Glyph 2TB USB3 HDD, Mojave 10.14.6. Pro Tools Ultimate 2021.3, HD Native, Focusrite Red 8Pre (Mac) Pro Tools 2020.12, Mbox3 (Win) Presonus Faderport, Pro Tools | Control |
Cool thanks - patched the TB/Slate out into a spare line in and it seems to be working better
Source Talkback AAX gets auto talkback | MIKEROPHONICS | Post - Surround - Video | 0 | 11-20-2013 08:15 AM |
Source ZIP- a new nifty utility from those Source Connect People | MIKEROPHONICS | Pro Tools TDM Systems (Mac) | 0 | 01-13-2010 09:05 AM |
source-elements.com/Source-Connect | clusterer | Pro Tools TDM Systems (Mac) | 3 | 10-30-2005 05:16 AM |
Internal talkback Routing for Procontrol newbie | Shatner | ProControl, Control|24, Command|8 | 2 | 03-15-2004 04:10 PM |
Signal Routing w/talkback | soundasylum | ProControl, Control|24, Command|8 | 7 | 07-20-2001 12:50 AM |
