Old 02-21-2011, 02:44 PM
SteveC7 SteveC7 is offline
Default New MBox2/PTLE 7.3.1 user - 7.4 upgrade question
Hi all,
First post here...
I recently purchased a used MBox2 w/ PTLE 7.3.1 from a coworker. My coworker also purchased a paid upgrade to PTLE 7.4 at that time back in 2008, but only downloaded the Mac version since that's what he was using. I already have PTLE 7.3.1 up and running but would like to download the Windows version of the 7.4 upgrade as well since I don't have a Mac. Plus, PTLE 7.3.1 won't run on my Vista partition so I have no "real" interface to use for any of my audio apps there.
I have a copy of the PTLE 7.4 upgrade confirmation email, as well as the Authorization code. But what I can't seem to figure out is how to access the full download itself - I can only see the "cs" udates. Any ideas?
Thanks
SteveC
Old 02-24-2011, 11:59 AM
Default Re: New MBox2/PTLE 7.3.1 user - 7.4 upgrade question
Well... I was able to resolve this the old-fashioned way - my coworker found his Avid login and password in order to access the full Windows 7.4 download.
I had a @#$% of a time trying to get it installed on Vista though... I kept getting a "Microsoft Register Server has stopped working" error when the installer reached the point where the drivers were being installed. I must have uninstalled/reinstalled/repaired about 10 times, with varying combinations of Run as Admin and XP Compatibility mode, but just couldn't get the installer to finish and register everything.
I finally located a post on these boards suggesting to change the default DEP setting - not just adding regsvr.exe to the exclude list - and that did the trick! Well, almost... I had to manually update the MBOX2 audio drivers after the fact since PTLE couldn't find any hardware device. But now I'm finally up and running, and have a real interface to use on my Vista partition.
Now comes the easy part - learning PTLE...
Potential PTLE user with a question: Krobar Pro Tools M-Powered (Mac) 11 08-17-2009 10:35 AM
Upgrade question - can I use mbox2 micro upgrade on 002 system? spreston 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-22-2009 11:22 AM
Pleese answer s/pidf question for mbox2 user lostwaveproductions 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 05-20-2008 08:26 PM
Very simple question from non-techie Mbox2 user SessionSinger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-05-2007 01:49 AM
Mbox2 and my PTLE 7.0 upgrade??? casperfun 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-10-2005 12:24 PM
