Old 10-29-2002, 05:49 AM
poldo poldo is offline
Default waves audiosuite trouble in HD platform
Anyone experienced the follow annoying bug using Waves processor Audiosuite mode in HD platform?
1)You are processing a file with a Waves Plugin, such xnoise or q10, or any other, in Audiosuite mode...
2)Now you keep the same waveform selection and from the AS plugin popup you choose a Digidesign plug such i.e. Gain or Reverse, or Limiter...
3)You make the appropriate adjustments of settings and you press "Process"
4)The result is and error dialog that tell you that Audiosuite plugs processes 48 channels at time and you must close the plig and re-boot it from Audiosuite Menu
AJP
Hotminds Multimedia Group
We always keep on trying
Old 10-29-2002, 05:52 AM
Dutchmuzik Dutchmuzik is offline
Default Re: waves audiosuite trouble in HD platform
YES I get this as well I am not sure if it is only waves but I get it when I switch to Serato Pitch n TIme. "This plug-in can't process 48 tracks at a time" something like that.
Old 10-29-2002, 06:22 AM
yeah!
I think this is a little HD or Waves package bug...
People at Digi, take a note for next update!
AJP
Old 10-29-2002, 09:45 AM
Pirate Post Pirate Post is offline
On November 19, 2001 (yes, 2001) I received a reply from Waves that they were able to recreate the bug and it happens with all of the Restoration Plug-Ins. I think they forgot about this one.
Pirate Post
Peter Cole - Head Pirate
http://www.beforenoonpost.com
http://www.piratepost.net
Old 10-29-2002, 03:56 PM
PastaViking II PastaViking II is offline
I don't think it's a Waves bug but rather a Digi bug since I sometimes get the same error with simple AS plugins like "gain". Restarting ProTools or sometimes loading a different plugin, change the selection and then go back solves this...
But most annoying indeed.
Speaking of annoying PT bugs:
When importing audio - if I select another disk in the menu and there's a file selected in the current, rather than going to that disk the file gets moved to the import box! If there's no file selected it behaves normally. Bvadr! [img]images/icons/frown.gif[/img]
Old 10-29-2002, 09:03 PM
benderbro benderbro is offline
yup, I get the same problem with the basic digi AS plugins, I have to close the plugin and then reopen it which always works but it's a drag
"this guitar won't play that"
Old 10-30-2002, 10:53 AM
Mr T Mr T is offline
This is not an "HD only" problem, I've also experienced it (mostly using Waves or Pitch N Time) with a TDM system and a Digi001 system...
Annoying indeed...
Some music?... http://tmweb.free.fr
Old 10-31-2002, 06:55 AM
DigiTechSupt's Avatar
<font size="2" face="Verdana, Arial">Up until this point, we have only been able to reproduce when Waves plug-ins are involved.
What steps are you doing to provoke the error when using only DigiRack AS plugins? Is it after one process or is it after the 2nd process of a different plug-in (but the same selected audio)?
Brent
Avid Audio Tech Support
Support FAQ
Trouble with Audiosuite Pitch shift Mark Seyler 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-10-2011 07:11 AM
Waves V6 can't use "Audiosuite" modulo2008 Pro Tools TDM Systems (Mac) 2 07-09-2008 09:29 AM
trouble adding plug-ins to audiosuite clingerpratt 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-12-2008 07:45 AM
trouble with audiosuite plug ins... oneamazinkid 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 01-02-2005 09:10 PM
Trouble with AudioSuite plugs Bezo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 10-09-2003 06:16 AM
