Old 11-07-2005, 10:44 AM
time808 time808 is offline
Default Adding more inputs with the 002
I know of the octopre to add 8 additional XLR inputs. Are there any others out there I could use? thanks!
Old 11-07-2005, 10:49 AM
bassntreble bassntreble is offline
Default Re: Adding more inputs with the 002
Alesis AI-3 and AI-4 add 8 analog I/O via lightpipe. No preamps though.
Presonus DigimaxLT adds 8 preamps/line inputs over lightpipe.
G5 1.8X2/3gigRAM/Mbox/7.4 (retired)
MBP C2D 2.4/4GigRAM/Mbox/8.0.1
iMac i7 3.4/16GigRAM/10.0.1
Old 11-07-2005, 10:53 AM
thanks. Is the octopre pretty much the best to go with?
Old 11-07-2005, 11:54 AM
mjteix mjteix is offline
I've been using a Mackie Onyx 800R ($1000) with a 001 config.
- 8 XLR mic pre-amps inputs, including 2 with 4 mic impedance options and Mid/Side function, and 2 Hi-Z instruments inputs.
- 8 Line inputs and 8 line outputs on DB-25 connectors.
- AES and ADAT output (up to 192KHz), world clock input.
I like this box, it sounds great, very clean, very stable clock.
It can also be used with other systems (ProTools HD, etc...)
Here are some other options (sweetwater prices):
M-Audio Octane $600
Presonus DigiMax LT $800
Focusrite Octopre LE $600 + A/D card $200
Mackie Onyx 800R $1000
Focusrite Octopre $800 + ADAT option $200
Presonus DigiMax 96K $1330
Old 11-07-2005, 12:20 PM
carlos santana carlos santana is offline
i use an behringer ada 8000
ightpipe 8 pres
Old 11-07-2005, 05:14 PM
Chris Shaeffer Chris Shaeffer is offline
Cheap, even partially broken, ADAT XT-20 or LX-20.
Cheapest way to get 8 channels of lighpipe i/o if you already have a mixer for pres.
Old 11-07-2005, 08:17 PM
taperocket taperocket is offline
I owned the Behringer ADA8000 and for the money it was great, however from what I hear, the way to go is the Maudio Octane, its essentially like having 8 channels of the DMP3 which if you don't know is a rather clear and open sounding pre. I think it should set you back about 600 or so. Good luck!
Pt 9.0.3 - Digi002R - Imac Dual 3.06 - 8GB RAM - Snow Leopard 10.6.8 - OWC Mercury Elite Pro HD - Akai MPK49
Old 11-08-2005, 05:16 AM
Atlam Atlam is offline
i am using an RME Octamic-D.
Great sounding pre-amps, tons of gain - connected to the Digi 002 via ADAT (optical).
Works a charm
Cheers,
Gavin Attard
Editor / Sound Designer / Audio Engineer
Liverpool
_____________
G5 2.3Ghz 2.5GB RAM
AL PB G4 1.6Ghz - 1.5GB RAM
002R, Mbox2
RME OCtamic - D
Old 11-10-2005, 02:11 AM
nitro-g nitro-g is offline
But do any of the expensive 96KHz options (the Focusrite Octopre or the RME Octamic-D for example) let you do full 96KHz sessions???
I've seen other things that suggest that the ADAT optical link will only work to 48KHz on a 002R?
Is this true?
Or can you add 8 extra analog inputs & work fully at 96KHz on a 002R using a Focusrite Octopre or RME Octamic-D & ADAT optical link? Is somebody actually doing this in their own studio?
Or would I only be able to work at 48KHz?
Many thanks for your help - would be most interesed to find out!
S.T.W.
Old 11-10-2005, 02:23 AM
Phil Jeffers Phil Jeffers is offline
The Alesis AI 4 is a AES/EBU to ADAT converter, so will only accept digital I/O. The AI 3 does as you say. Apparently the AI 4 can work at 96kHz by "sharing" channels. I don't think Digi's hardware supports this though. There are other line to ADAT converters also: Fostex is one... This gives you alternate I/O through ADAT, not pre-amps though as stated.
Adding inputs to Mbox 2 Pro jmrenna 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 3 09-14-2009 04:11 PM
Adding Inputs on Mini GraphicX 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 11 03-22-2008 12:49 AM
Adding inputs to PTLE Zatchamo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 03-29-2007 02:05 PM
Adding four more inputs WRX07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 01-29-2006 10:03 AM
adding inputs to M-Box mastershredder 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-19-2005 09:14 PM
