Hey ya'll.
Have installed 6.4 on my new DAW. PTLE is working fine. Reason works rewired. Reason also works stand-alone, using the 001 via ASIO. But I can't get Sonar 3 Producer Edition to find the 001 at all... any tips?? TOm. |
Is the 001 visible in the Options>Audio drop down menu?
No...nada.
But it works with Reason and Proj5 in standalone mode... bizarre, no? Tom. |
Bizarre it is. Have you re-installed PT LE since you've had Sonar on your PC?
Sonar was on there first. As was Reason and P5.
I installed PTLE 6.4 from upgrade CDs last. Any further ideas?? (It's not the hugest tragedy... now that PTLE has Rewire and can take VSTs, there's little reason to use Sonar anymore... except for the unlimited number of tracks.) T. |
check in the playback and recording modes in the advanced tab of the Audio Options and make sure it's on ASIO.
I've had a similar headache when this was set to something else. |
rock.
i'm not at my DAW, but will try that out. cheers, tom. |
ASIO Driver Problems with Sonar 8.0 and FL 8 | scottthafoo | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-22-2009 03:43 PM |
asio driver and sonar | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 04-01-2003 03:29 PM |
Cant get asio driver to work w sonar | neatguys | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-30-2003 11:03 PM |
Check it out ... SONAR to support 001 with ASIO | sonar_boy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-28-2002 01:07 PM |
Will ASIO work with Sonar?? | mix2much | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-12-2002 08:44 PM |
