Omni channel/meter order confusion
I'm new to the Omni and trying to use my it with both Pro Tools and Logic.
In Pro Tools, Outs 1&2 show up on Omni meters 1&3 for some reason, but output on 1&2 of the analog snake. Using Logic, Outs 1&2 show up on Omni meters 1&2 but output on analog 1&3. Both daws are setup to ITU channel order (L, R, C, LFE, LS, RS) |
Re: Omni channel/meter order confusion
First your provided info is very limited. You might want to at least list your computer type, OS version, and PT version.
That said: it sounds like talking about 5.1 surround I would think you would want to post in the Post.. Surround...Video forum, as I am guessing it is a PT routing and surround format issue
System : Studio - Avid Carbon interface , PT Ultimate 2023.12 Mid 2020 (intel) iMac 27" Ventura 13.2 .1 Mobile - 2021 14 " MBP M1 Pro PT Ultimate 2023.12.1 Sonoma 14.4 Enjoy the Journey.... Kev... |
Mac Pro 3.33 6 Core, OS 10.8.5, HD Omni, PT 11 HD, Logic 9, Focal CMS Monitors.
I do believe this is the appropriate section to post in as it applies to stereo as well as surround. |
Well Ok then my system is stereo only no surround. In my PTHDN system .... Outputs 1 & 2 in the I/O show up on Omni meters 1 & 2.
I happend to vaguely remember reading either here ( in the Post/Surround forum ) or over on GS in the Post Production forum....... something about PT outputs surround channels in film order (L, C, R, Ls, Rs, LFE). not (L, R, C, LFE, LS, RS) which could be you problem or not. I cant help you as I only work in stereo I'm guessing probably the people who actually work in 5.1 surround would be more likely have some answers for you, or suggestions on how to diagnose what is going on . Thus the suggestion of posting in a forum populated by people who work in surround. Just a thought good luck
Yes, I just confirmed that it does output 5.1 in film order. Stereo projects map L, R to outs 1 & 2.
Thank you.
2018 3.2 GHz Mac Mini 6 Core, OS 11.6.8 64GB Ram PT Ultimate 22.7.0 - EuControl 22.4 - Avid Omni - Pro Tools Dock - JBL 705p Monitors - JBL Intonato 24 Monitor Controller |
I've had questions about this, but never had time to trouble shoot. Similarly my OMNI meters show stereo on 1 & 3, but actually output on DB25 1 & 2. Problem arrises when I try and use the headphone jack on the HDN TB box because you only hear one side (i.e. it's seeing what the METERS are reflecting). I have a 5.1 monitor path (Since I mix surround regularly) and map stereo output to that path. If I change to a STEREO monitor (in the I/O setup) then meters match outputs match headphone on TB box so that was my workaround. Sure would like to know what's going on though.
Tim Reisig Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram) |
I agree. It's really odd that this hasn't been fixed in an update. I'm glad to see that I'm not the only one that was puzzled by this. If ITU channel order is selected in the setup, the outputs should reflect it.
Is your Io in PT set up to C24 defaults???
Jay Litehousemuzik Audio Mixing Services |
Nope. I checked that...
Inserts affecting send meter but not channel meter? | Kbrinson85 | Windows | 1 | 05-01-2012 07:00 AM |
OMNI I/O Confusion | CJG | Pro Tools TDM Systems (Mac) | 7 | 01-25-2012 01:09 AM |
Omni confusion | ejwells | Pro Tools 10 | 4 | 01-13-2012 07:09 AM |
Tempo/Meter Confusion, Please Help | detroitkruk | Pro Tools TDM Systems (Mac) | 9 | 08-08-2005 12:02 PM |
A suggestion regarding the continuing confusion about card order | ragbor | Pro Tools TDM Systems (Mac) | 0 | 05-08-2001 12:12 AM |
