Syncing 2 Omni
Hey Gang,
I need to sync (Time Code) 2 Omni together on two different computers for the transfer of audio tracks. Can anyone tell me the best way to do this? Thanks, mike Last edited by mike841; 12-15-2015 at 08:40 PM. |
Re: Syncing 2 Omni
Connect them on a network with a switch. In the peripherals / Satellites page, Select on a the admin and one as a satellite. That should get you very close to sample accurate sync.
You can also just import the data from on session to another session. I'm not totally sure what you are trying to accomplish here.
Brandon Howlett Vibe Audio Post, Inc. Re-recording Mixer Custom Build CPU, HDX 1, Omni, 192 I/O Digital S6 M10 24 fader Satellite Mac Pro, HDNative, 192 I/0 Black Magic HD Extreme |
Re: Syncing 2 Omni
Thanx-a-bunch Brandon,
I know I didn't go into a lot of detail. I need to run the tracks thru outboard gear, so importing won't work. Also, when you say "peripherals page", do you mean in Pro Tools? Not using Pro Tools, using Nuendo. Do you know if the Avid Sync HD unit will work? I wasn't sure because the Omni does not have smpte or midi ports. |
Re: Syncing 2 Omni
in Pro Tools
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Re: Syncing 2 Omni
Sorry. This is a pro tools forum. No clue how to do this in nuendo but they do have a vst link function. Can't you use that?,
Re: Syncing 2 Omni
Also the HD sync will not work outside of pro tools. You need something that works with nuendo.
Re: Syncing 2 Omni
I know it's crazy to be posting this on a PT forum but to me it was more of a hardware issue, and all of Avid's other hardware works smoothly with Cubase, so I was wondering if the Sync HD would too.
I prefer Cubase over PT for creation, but their peripherals are clumsy. Thanks for the help. -mike |
Re: Syncing 2 Omni
Wouldn't a simple word clock sync cable work???
I don't see why not.... Put the receiving OMNI in slave or External and put the sending Omni in Internal.... Should lock just fine//
Jay Litehousemuzik Audio Mixing Services |
Omni vs HD 8x8x8 io and Omni Pre's | Southsidemusic | Pro Tools HDX & HD Native Systems (Mac) | 13 | 03-27-2013 01:00 AM |
OMNI Fried? Calling Omni Members - Check High Samplerates | KingFish | Pro Tools TDM Systems (Mac) | 3 | 11-03-2011 09:19 PM |
Be aware! Potential HD Omni buyers with treated Rooms and Computers. Omni Noisy Fan | FRaNCo MuSiC | Pro Tools HDX & HD Native Systems (Win) | 0 | 09-25-2011 05:42 AM |
Syncing with MTC | Chompers | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 04-29-2002 06:36 AM |
Syncing with PT 5 LE????? | JRogers | General Discussion | 0 | 11-22-1999 10:38 AM |
