Old 08-31-2009, 10:15 AM
Dizzi45Z Dizzi45Z is offline
Default Okay... Am I an idiot or what.. Mac Pro Digital Input Output
I know this isn't that much Pro Tools related, but I am having a really hard time finding any information on the Digital Audio Inputs and Outputs that are built into the Mac Pros.
I am trying to connect my mac pro Digital inputs/outputs to my Tascam DM-3200 ADAT in and outs. I have not been able to get it to work, but now I just think I realized something... Or at least I have a theory that if I am correct, I am a complete idiot. Is it true that not all Optical connections are the same? In other words, are the Digital outputs from a Mac Pro not ADAT even though they both use Optical connections?
If so, I am an idiot. The whole time I thought Mac Pro's came with 8 digital ins and outs because of the optical audio connections. If this isn't true, then what kind of Digital interface do I need to use the built in Audio from the Mac Pro? I would prefer to just leave my 192 Digital to be used only with my HD set-up and the Digital inputs and outputs for all other audio. Thanks.
recording.guru : FREE Pro Tools Tips and 19 Video Basic Training Course
Pro Tools HDX 2023.9
Mac Pro 7,1 3.2 GHz 16-Core Xeon W
160 GB RAM
macOS 11.7.4
Noisebox Studios -Utah Recording Studio
Old 08-31-2009, 10:27 AM
Drew Mazurek's Avatar
Default Re: Okay... Am I an idiot or what.. Mac Pro Digital Input Output
Honest mistake.
You've got connectors, in this case a Toslink Optical, and then you've got Formats. Two different things. Optical can carry SDPIF, Dolby Digital, or ADAT, etc.
www.drewmazurek.com
Old 08-31-2009, 10:39 AM
Originally Posted by dmazurek View Post
Honest mistake.
I haven't purchased a new home theatre system since 1993. This probably explains why I made this mistake. I also always thought that SPDIF was sent through the RCA style (digital coaxical) SPDIF cables. But it sounds like it is also sent through digital optical.
So I would need to get an AV receiver if I was to use the built in Digital connections?
160 GB RAM
macOS 11.7.4
Old 08-31-2009, 11:25 AM
gonsdeejay's Avatar
gonsdeejay gonsdeejay is offline
If your Tascam 3200 Let you to set on the Digital Preferences, The ADAT As SPDIF, If I remember, TYascam 3200 has it Two Sets Of ADATS I Mean 1-8 and 9-16, Try to set 9-16 ADAT (second port) as SPDIF To Get a Digital Connection between Both Your MAC PRO and Tascam 3200. in My case, I Use that Digital Output Input, With an Old MINI DISC as DIGITAL CONVERTER, I just have turn On, Select the Optical Input on the MINI DISC, and Set my MAC PRO To Digital I/O and Done.
Pro Tools 2021.12 UAudio Apollo X8, 8 Duo & Apollo Twin. Mac mini M1 8 on Ram, 256gb, Thunderbolt 3 KRK V88. Yamaha HS7 Korg ESX-1 MBOX2 003Rack Producing My Own Life
Old 08-31-2009, 11:30 AM
That is good to know. I will check it out.
160 GB RAM
macOS 11.7.4
Old 08-31-2009, 12:56 PM
groovebrother groovebrother is offline
(not sure to have read it in this topic), the digital in & out from a MP through a toslink cable are spdif
My soundcloud page
Mac Pro 2x 2.66GHz 6-Core / 96 Go Ram / PE6R4-i - HD Native - Tempo Sata Pro 6Gb - PTHD : 10 / 11 /12 / Ultimate till 2022.5 - 192 i/o Digidesign - MTPAV - OSX : 10.4 / 10.5 / 10.6.8 / 10.8.5 / 10.9.5 / 10.11.6 / 10.13.6 / 10.14.6 - PowerMac G4 MDD / Pro Tools HD 5.3 / 6 / 7.4x / 8
Can't output to digital I/O bing181 macOS 1 10-04-2013 03:36 PM
Is there a way to use a digital input at 96k from a digital output at 48k? rockguitarist1255 Pro Tools 10 3 01-04-2012 05:48 PM
Can I use the digital output from my Mac? Starcrash 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 02-22-2007 03:14 PM
Mbox Analog Input with Digital Output Alhuero 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-27-2003 11:59 AM
Digital Output from 888/16 isn't compatible with Digital Input of TC M2000 & PCM 80 beerbr Pro Tools TDM Systems (Mac) 0 11-02-2000 08:01 PM
