Old 11-12-2004, 11:27 PM
DJ Tonic DJ Tonic is offline
Default Mac built in sound output distorted...
Hi, I'm using the output on the mac soundcard to monitor when working in reason, and just recently Its gotten way louder to the point of distortion, I've changed nothing. I've tried everything I can think of and its still distorting. Anyone ever had this problem? Know how to fix it? Thanks.
G4 MDD Dual 867 1 Gig RAM
Digi 002
80 Gig Lacie Audio drive
Alesis M1 Active MK2 Monitors
Radium 49 MIDI Controller
Old 11-13-2004, 02:23 AM
maccool maccool is offline
Default Re: Mac built in sound output distorted...
have you recently upgrade Panther to 10.3.6?
Dual 2.0 G5, 10.4.6, PTLE 7.1, 002R
Old 11-14-2004, 09:26 PM
Yeah I did recently go to 10.3.6. You think that has something to do with this?
Digi 002
Old 11-14-2004, 09:49 PM
Reason still sounds great on my PowerBook built-in audio, using 10.3.6, into Cambridge Soundworks speakers.
Quad 2.5 G5, 4.5G RAM
Old 11-15-2004, 12:03 PM
maybe troll through here at xlr8yourmac, or check out the Apple Discussions, there are reports of something similar. Some say that zapping the PRAM fixed it for them, maybe give that a go in the first instance. I've done the upgrade to 10.3.6, although not on my ProTools' System, and so far the only problem I've had is with Calculator, another common complaint, but not from everyone. Go figure.
Old 11-15-2004, 12:09 PM
I had a problem with Calculator - wouldn't display unless I selected Show Paper Tape. Trashing calculator preferences fixed it.
Old 11-15-2004, 05:45 PM
I tried trashing PRAM and it didn't work. Gonna go check out the apple forum and see if anyone knows there.
Digi 002
Old 11-15-2004, 06:26 PM
Just checked the apple forum. Seems that this distorted output is common mostly among G4 owners and only after 10.3.6 was installed. The only answer I could find was to go back to 10.3.5, or as a temporary fix if you unplug the cord from the output mini jack then plug back in it fixes the problem till the next time you boot then you have to do it again.....Weird. Should have just stuck with 10.3.5.
Digi 002
HDX & Built-in Digital Output? sfere1 Pro Tools HDX & HD Native Systems (Mac) 1 11-03-2012 07:45 PM
[solved] No sound thru MacPro Built-in Line Output with PT10 Lakhbir macOS 9 11-13-2011 07:08 PM
Nothing but loub buzz whenever I try to use built-in output EricWillhelm macOS 0 09-27-2011 11:26 AM
No output from Mbox: built-in phone output only DaveSullivan 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-19-2006 06:03 PM
Sound Output resets to "Built-in" on every reboot Gremz 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 04-12-2001 12:43 AM
