ARA now available! in Reaper...
hope PT catches up soon!
My ears! My ears! clausiii ----------------- MacBook Pro i7 Quad 2.6GHz 16GB RAM ProTools 2020.11 Avid S1 Avid Dock Avid Control Digidesign Command|8 macOS Catalina MOTU 4pre MOTU Track16 Axiom Pro 25 LinnStrument 128 Roli Seaboard Block tons of stomp boxes tube amps guitars noise |
Re: ARA now available! in Reaper...
Agreed.
I remember Digidesign said faster than real time bounce was impossible to implement because of TDM architecture. Then some years later it magically appeared. Let's hope the same applies for ARA Stephen
Mac mini M1 2020 16Gb Memory- 256Gb Storage, Monterey, Pro Tools 2022.9, Focusrite Scarlett 2i2 https://www.waves.com/r/djgsi6 |
Faster than real time bounce is still not possible with the TDM architecture. But it is with HDX, etc.
Well, no! Afaik during (offline) bounce PT switches to native. Or is bouncing on HDX different/faster/better than on native?
TDM it was not possible. HDX it is not possible. It is just the AAX-DSP plugins are switched to native to do faster than realtime bounce (all AAX-DSP plugins are required to have a compiled, native AAX-only versions for that reason; that was a change from TDM plugins which did not have that requirement and it was sometimes not possible.) There is no faster than realtime happening with the actual AAX-DSP/HDX cards. Avid never lied in either case.
Pro Tools Ult 2024.3, HDX 2, MTRX/SPQ, RME BBF Pro + MADIface Pro • S1 x 2, Fire HD10 + Max11, Dock, iPad Air5 • Mac Mini 14,12, 12 core, macOS 13.6.5 • RAM 32GB, SSD 4TB, GPU 19 core • QNAP TVS-872XT 148TB TB3 |
Had the pleasure of using ARA in Logic for the first time recently. Agreed, this is something Avid needs to implement tout suite.
Custom i9-12900K, 64GB RAM, W10 Pro, PT Ultimate 2024.03, HD Native, OMNI, Digi 192, UAD-2 Octo; Mac Pro 12-core 3.46, 64GB RAM, Mojave, Logic Pro 10.5.1, Apogee Rosetta 800, UAD-2 Quad, MOTU 2408 Mk II: MBP mid-2012, 16GB RAM, Mojave, MOTU 8-Pre-ES, Pro Tools 2021.7 |
Off-line bounce required the overhaul of plugins to the AAX format. ARA is on the radar, for sure.
The point being that something was apparently impossible with Pro Tools and then it became possible.
Let's hope that happens with ARA Stephen
It will not happen. But this: Trackpacks, Buspacks, Extrasubscription to use automation, more fancy marketing videos.
They said that for faster than real time bounce Stephen
Making Reaper Look Like PT | DonaldM | Tips & Tricks | 8 | 03-24-2015 01:32 PM |
Reaper not in Plugins | dacoma09 | AAX Plug-ins | 11 | 11-24-2013 09:31 AM |
Which version of Reaper do I need? | paulrgmusic | Tips & Tricks | 4 | 06-11-2010 04:49 PM |
Open Reaper 64 in PT. Possible ? | shutiri | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 05-03-2010 01:56 AM |
If you're moving to Reaper get on with it! | rqstudio | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 32 | 04-04-2010 03:44 PM |
