Double display on Mac OS Sierra
Hi
I'm working with a double display configuration, obviously I haveMix window on one side and Edit in the other. I have tryied saving project with my prefered config, saving config preference and saving atemplate, but PT is always opening my projects in a one display configuration !!! Any tip about this ? I'm on PT 2018.4 |
Re: Double display on Mac OS Sierra
Yes, I'd like to know this too. Seems like previous versions of PT were able to remember window configurations so it's irritating that the current version can't.
It's not just the current version, this annoying window configuration issue has been going on for years. I can't even remember the last time PT did remember window positions properly. So it's not just with Sierra either.
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc |
Save your preferred configuration as a Window Configuration and you can recall it with a quick shortcut when you open the session. If you save it into your template it will always be there.
Scott Gatteño |
Yes as Scott’s mentioned above.
Window configs recall mosly works. Some float-windows still do not behave. ((Config window, system usage do not hold. )) Most do do behave now (in my config)
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
Working fine here with PT 12.8.1 on Sierra on a late 2013 trashcan. Mac has never given me any problem with this, unlike Windows. It has worked right for me for 23 years, since PT 3.1.
I wish I could pass on a tip to help. At the moment, I happen to be using a pair of ASUS displays. One is connected by HDMI, the other by thunderbolt with a DVI connector. My coworker has two Apple displays connected to a MacBook Pro, and he has no problems, either.
David J. Finnamore PT 2023.12 Ultimate | Clarett+ 8Pre | macOS 13.6.3 on a MacBook Pro M1 Max PT 2023.12 | Saffire Pro 40 | Win10 latest, HP Z440 64GB |
I have the same issue running three monitors, I always have to move the mix window to my second monitor. Saving a config and loading it takes as much time as moving it by hand so no real point there if if doesn’t remember the next time pro tools is launched. I have a gtx 980ti.
Mac Pro 5,1 12 core 3.46ghz OS X 12.6.1 Opencore 0.8.6 Pro Tools Ultimate 2022.10 Mac Pro 2009 upgraded to 5,1 12 core 3.46ghz GPU RX6800XT, Samsung 970 EVO Plus pcie boot drive, Titan Ridge flashed for Mac. Midas M32r console. iPad Pro with Avid Control |
Configs can be recalled by the keystroke sequence .n* where n is any digit on the numpad. Once you get the hang of it, it takes about 1/10 of a second to recall. My co-worker and I have very different workflow styles, and share sessions, so I always create each tracking session with two window configs, one for me and one for him. When I'm done tracking, I hit .2* and save, and it comes up just right for him next time he opens it.
Windows Config doesn't work for me either - I can save the configuration, but using the Config just moves the Mix window back to the other screen. My Mix windows only stays on the second monitor if I don't have it maximized. Really annoying problem, but I just keep that window slightly less than maximized and move on...
Help Us Help You ______________________________________ Chris Pro Tools 2024.3 Focusrite LS56 Focusrite Pro40 (3) Slate Digital VRS8 Analogue Tonebuss 24 Channel UAD-2 OCTO Core Accelerator UAD Volt 2 macOS 10.15.7 32 GB DDR4 RAM 4.01GHz Quad-Core Intel Core I7 NVIDIA GeForce GT 740 2 GB |
Ah. I've never maximized my windows. I guess that's the "secret."
Question: Sierra or High Sierra for PTHD 2018.3? | johnnyv | Pro Tools 2018 | 25 | 03-18-2018 08:30 PM |
S-MUX / Double Speed / Double wire | jiggy_bau | Pro Tools TDM Systems (Mac) | 3 | 06-27-2005 09:36 AM |
Good news in double-display-land | MattiMattMatt | Pro Tools TDM Systems (Mac) | 8 | 02-06-2002 04:18 AM |
Good news in double-display-land | MattiMattMatt | Pro Tools TDM Systems (Mac) | 0 | 02-05-2002 09:57 AM |
Double Cinema Display? | Joris Vincken | Pro Tools TDM Systems (Mac) | 5 | 01-22-2002 12:55 AM |
