Old 06-18-2013, 04:16 PM
Arrun Arrun is offline
Default Some plugins don't show up in Audiosuite
So, I'm absolutely loving how convenient this whole offline modulation and stuff is, especially coming from something like reason where there really is no equivalent, however I am finding it perplexing that multiple plugins, both Air ones and by 3rd parties are not showing up!
For example, two of the Air plugins I abuse the crap out of - Frequency shifter and phaser - don't show up, nor do multiple waves plugins and also Fabfilter ProQ amongst many others.
I don't understand because they all show up as inserts on regular tracks, just not in audiosuite!
Does anyone know what's going/what I can do to fix it?
Much appreciated,
Arrun
Old 06-19-2013, 01:36 AM
crizdee's Avatar
crizdee crizdee is offline
Default Re: Some plugins don't show up in Audiosuite
Much appreciated,
Arrun
Not all plugins are available as audiosuite. Some vendors don't make an audiosuite version and some plugins are not able to process direct to disk.
Chris
Producer, Engineer,
www.ukmastering.com
Old 06-19-2013, 09:20 AM
Originally Posted by crizdee View Post
Chris
I see, but it's still makes little sense to me that for example a digidesign Flanger and a Waves Metaflanger will work, but the digidesign phaser doesn't??
Old 06-22-2013, 05:21 AM
ondruspat ondruspat is offline
Arrun, keep in mind that even if a plugin creates the same effect what's under the hood can be totally different.
"Sometimes having limits keeps you sane"- Albee1952
Audiosuite plugins won't show??? Raoul23 Pro Tools 10 10 03-14-2014 10:56 AM
PT10.2 Waves v9 AudioSuite PlugIns won't show up synkope76 macOS 3 09-17-2012 12:19 PM
Time Shift: Doesn't Show Up In AudioSuite Window Curve Dominant 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-26-2007 12:46 PM
Audiosuite plugins don't show on second monitor Wayne B Pro Tools TDM Systems (Mac) 2 09-06-2003 05:55 AM
my audiosuite waves plugins show up double in the pull down menu peter parker 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-31-2002 12:56 AM
