Old 04-18-2013, 12:18 PM
Raoul23 Raoul23 is offline
Default Big gang/crowd vocals
Hi guys I'm recording a band at the mo who want some gang vocal like this. Check out http://youtu.be/2NTyyCwwDfY?t=3m6s
Can people suggest how to do this. Is the secret to record about 20 takes of the 4 band members shouting the lyrics ???
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 5.1 12 Core 3.46hz Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 04-18-2013, 12:56 PM
BroomPole BroomPole is offline
Default Re: Big gang vocals how to!
Just finished recording a punk band with some similar shout outs. I usually find when doing it the best results come from 3-6 dudes in a semi circle around a LDC. Then double take it panning one left and right. I find it gets pretty muddy really fast if you go much over two or three takes. At that point you might want more people.
That song you posted sounds to me like what I just recorded with two takes though.
cheers
Kevin
Old 04-18-2013, 01:03 PM
cheers
Kevin
Cheers Kevin for chiming in we did try 3 of the band members shouting the part twice and I even panned them full left and full right. I just found it doesn't sound as crowdy if that makes sense. In the link I posted I thought there were more people in the gang ?
Raoul Crane
Old 04-18-2013, 01:31 PM
TruestPain TruestPain is offline
To capture this in a studio session. Would this be the same technique as to capture a "crowd" or what could appear as a crowd* vocally, such as when certain songs have like a chant going on or repeating a specific sentence of a hook or a bridge.
How and what is the best way to capture this?
Old 04-18-2013, 01:32 PM
Originally Posted by TruestPain View Post
To capture this in a studio session. Would this be the same technique as to capture a "crowd" or what could appear as a ground vocally, such as when certain songs have like a chant going on or repeating a specific sentence of a hook or a bridge.
Yeah that's what I'm after the BIG crowd chanting sound
Raoul Crane
Old 04-18-2013, 02:28 PM
Craig F Craig F is offline
it is a good time to have friends & girlfriends stop by to make the group larger
having people move around between takes and if the can change there range even better
Thank you,
Craig
Old 04-18-2013, 02:52 PM
Stig Eliassen's Avatar
Also, keep some distance to the mic(s). When did you ever have 50 people 1' away from your "ears"?
Old 04-18-2013, 03:29 PM
ondruspat ondruspat is offline
Craig and PT's suggestions are both good ones. Also remember to do a few takes where no one cares about singing in key. Part of a crowd singing is the disonance of crappy singers!!!
"Sometimes having limits keeps you sane"- Albee1952
Old 04-18-2013, 04:41 PM
I took a mobile rig to a party one time for the party track
DA-88 w/ a mix on 1&2 (mono, phase flipped on 2)
mic pres
stereo LDC
and a pair of powered speakers
fun night
Thank you,
Craig
Old 04-18-2013, 05:10 PM
Bill@Avid's Avatar
Bill@Avid Bill@Avid is offline
I don’t know if this is helpful or what you’re looking for but this was my tried and true big hair big chorus formula circa 1986.
I’d collect up all of the guys in the band that could sing (three if I was lucky maybe four). More than a few people and it would get pretty loose and unintelligible.
I’d position them standing arm’s length from either side of a c414 in figure 8. (+1 on the distance makes a crowd). I had a pretty vanilla room, not too live not too dead, and arm’s length provided just enough room sound.
I’d get one take that sounded good and tight and then do three more playing only the original take for reference to keep things tight. When I had four tight takes this was usually enough to get a big polished sound. A little HPF EQ and some sucking out the boxy mids is it was pretty straight forward gang vocal.
Here’s where it gets stupid. If I was going for that huge “noise reduction out sound” I’d repeat the steps above and ask the guys to pretend to be someone else. I’d take looser and pitcher takes as well. Usually this set would get mashed with compression and eviscerated with EQ so that all you got was the presence and sibilance. You could EQ the pitch out of them so the just added the suggestion bad singing and some extra mass. I would blend this second set with the polished set to make them a little uglier.
On rare occasions if the song called for that extra push over the cliff I’d mult them as a group, cut all the lows and mids, and then excite or distort just the high frequencies then bring this up in parallel behind the original. Sometimes I’d noise gate them really tightly and get them to snap in and out of existence. In reflection I think we were trying to emulate (no pun intended) sounds of background vocals that we being triggered by live acts using the 8 and 12 bit samplers of the day.
Good times! That was cathartic, sorry for the novella
Can I gang 2 MBOXes for more inputs? david kowalski 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-02-2008 04:19 PM
hi gang... I just finished up our new web site... georgia Post - Surround - Video 7 08-31-2006 09:33 AM
Post Q #2: How to gang several ProTools? Bokir Post - Surround - Video 6 04-14-2004 02:46 PM
kool and the gang production badperson 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 29 09-04-2003 05:20 PM
Gang Box Design/Diagram paulpatras General Discussion 0 11-27-2002 09:45 AM
