  #41
Old 12-03-2018, 07:39 PM
BScout BScout is offline
Default Re: Video Card - Mac Pro High Sierra & Native
Mine (and everyone who has a retail box) comes with power cables for the Mac and power cables for PC. When using the SATA power from the optical bay, you need the power cables for the PC plus an adapter to mate it to the SATA power supply.
Pro Tools Ult 2018.12, HDX 3, MTRX/SPQ, HD OmniMac Pro 5,1 - 3.06 GHz 12 core - macOS 10.13.6RAM 64GB, SSD 4 x 2TB, GPU GTX 980 4GB
  #42
Old 12-06-2018, 08:36 AM
the.engineer the.engineer is offline
Originally Posted by LDS View Post
Yeah, it seems like a bit of a minefield out there in this regard. Just to clarify, when you say you spliced into the PCIe AUX power for your HDX card, would using a simple 6-pin mini-PCIe Aux 'Y' cable achieve the same thing? I have a Mac Edition GTX 680 sitting here that uses 60w less power than your 280x, so the same solution should work fine.
Yes, same thing. I cut the mini 6-pin to large 6-pin in half, then using a pinout diagram and multimeter made sure I knew which pins on the four pin HDX connector needed 12V and gnd and soldered them all together again!
Click image for larger version
Name:	Photo 01-12-2018, 16 33 32.jpg
James Welch
Recording Engineer | Producer
Masterlink Productions
Mac Pro 5,1 (Mid 2010) | 3.46GHz Six-Core Intel Xeon | 32GB Ram | AMD Radeon R9 280X 3072 MB | 256GB Samsung SM951 SSD Blade (PCIe) System Drive | 1TB WDC Sample Drive | 4TB RAID 0 Seagate Audio Drive | UAD-2 Quad PCIe
Sierra 10.12.6 | Pro Tools Ultimate 2018.10 | HDX | Avid Omni | Avid 16x16 HD I/O x2 | Digidesign 192 | Digidesign C24
  #43
Old 02-03-2019, 10:56 AM
1m1 1m1 is offline
Originally Posted by off the wall View Post
I'm running the power for my HDX card off of one of the unused SATA ports on my 2010 Mac Pro.
See this post for details:
http://duc.avid.com/showpost.php?p=2491563&postcount=34
All of the SATA to 6 pin PCI-e cables that I've seen are 15 pins. Do you have to modify the plug to get it to work with the 22 pin SATA in the Mac Pro?
  #44
Old 02-03-2019, 12:07 PM
off the wall's Avatar
You have to trim off the locking tab on one side of the SATA connector.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 36GB RAM, MacOS 10.13.6.
Pro Tools Ultimate 2018.12. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
  #45
Old 02-03-2019, 12:18 PM
1m1 1m1 is offline
thanks! that's the answer I was looking for. Does the connector slide side-to-side without the locking tab, or does it sit securely in place without anything holding it there?
  #46
Old 02-03-2019, 01:14 PM
It does not slide side to side since the other tab is still there. I put a cable tie on mine so that it wouldn’t slide out since friction is the only thing holding it in.
  #47
Old 02-03-2019, 02:26 PM
1m1 1m1 is offline
thank you!
S6L AVB with OS X High Sierra brinnbacka VENUE Live Sound Systems 3 10-20-2018 12:52 AM
Question: Sierra or High Sierra for PTHD 2018.3? johnnyv Pro Tools 2018 25 03-18-2018 08:30 PM
MAC PRO High Sierra & PTHD 2018 can't recognized PCIe Native card Sutee Sangsareechon Pro Tools 2018 0 02-09-2018 11:49 AM
High Sample rates with Native HD card Media Man Pro Tools Software (Win) 6 02-27-2017 11:48 AM
HD Native card physically generates high pitch whine or squeal mlange Pro Tools HDX & HD Native Systems (Win) 6 03-15-2012 02:59 AM
