Go Back   Avid Pro Audio Community > Pro Tools Hardware > Third Party Interfaces
Old 05-19-2018, 01:31 PM
Rvoid17 Rvoid17 is offline
Default Windows 10/Thunderbolt suddenly not recognizing Apollo 8p
I've been running Pro Tools 12 with the Apollo 8p and a custom Windows PC. Motherboard is a Aeros Z27OX-Gaming 7. The Apollo is connected to a Thunderbolt 3 port via a Startech Thunderbolt 3/2 adapter.
Everything had been running fine. I turn on the Apollo, the cpu says "connecting Thunderbolt Device", launch Pro Tools, and off we go.
However, all of the sudden the computer doesn't seem to recognize the Apollo 8p in the Thunderbolt Port.
I've updated Windows, all drivers, downloaded latest firmware for the motherboard, uninstalled and reinstalled both the Thunderbolt Software and all UA software, power cycled, etc., and nothing seems to work.
BUT...it did work once, briefly. At some point, I told Thunderbolt to forget the Apollo device. Then, when I powered back on, it said "I see a new device", and then it was working. However, once I ended the session and powered down, it was the same problem all over again upon powering back up. Only this time, the same fix failed to work. When the device was recognized anew, the computer simply froze, and that's now happened multiple times.
Help?
Old 05-19-2018, 08:29 PM
Borg Borg is offline
Default Re: Windows 10/Thunderbolt suddenly not recognizing Apollo 8p
Make sure thunderbolt firmware is up to date on motherboard. This update is often separate and additional to BIOS update. According to UA support notes, NVM firmware should be 15 or higher.
- Borg
https://help.uaudio.com/hc/en-us/articles/214429386
www.foxmountain.com
@FoxMtnStudio
Old 05-21-2018, 08:25 AM
junkgear's Avatar
junkgear junkgear is offline
You can also check that Thunderbolt security is set to always allow in the BIOS. If not, you have to accept the device in Windows, which may be what you are doing when it works.
Will
System Details
is there any way to have Pro tools HD connected to Apollo 8p as a thunderbolt? Bearsounds Third Party Interfaces 11 03-23-2018 03:46 AM
UA Apollo Twin Thunderbolt - LIKE NEW booter Buy & Sell 1 03-22-2018 12:50 PM
Anyone using Apollo with thunderbolt on a windows setup? albee1952 Third Party Interfaces 3 09-18-2016 01:40 PM
Apollo - FireWire vs Thunderbolt mrgroovy Third Party Interfaces 3 12-20-2015 07:34 AM
Latency with Apollo thunderbolt juh macOS 8 11-27-2015 09:44 PM
