Old 12-02-2016, 07:58 AM
HotelRadio HotelRadio is offline
Default Pro Tools 12.6.1 taking a long time to open [solved]
Running Pro Tools HD on a 2012 Mac Pro, OSX 10.9.5 and have been using 12.4.0 since it was released. It's been mostly rock solid and opening the application never took more than a couple seconds. I installed 12.6.1 over it last night and now the Pro Tools icon just bounces up and down for 30 seconds before finally launching, scanning plugins etc.
Tried trashing preferences, restarting and reinstalling to no avail. Any ideas what could be causing this?
Old 12-02-2016, 08:23 AM
john1192 john1192 is offline
Default Re: Pro Tools 12.6.1 taking a long time to open
i have a pretty close system to yours and have no issues with 12.6.1 opening slow .. you know when you install a new version, if you rename the older version, pro tools 12.4, and the new version pro tools 12.6.1 you can use both ..
could this be a Plugin issue .. something is not up to date ??
something else you can do is to stop Avid Application Manager from Launching at startup .. might help
MacHD / library / launch agents / toss the avid application manager file ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 12-02-2016, 09:40 AM
DetroitT's Avatar
DetroitT DetroitT is online now
Pace, Boot Drive % used, Plug-in's and more
Just launched stopwatch and Pro Tools HD(x)12.6.1 with 250+ updated plug-ins and it took 45 seconds.
So there is hope.
OS 10.12.1, 2010 Mac Pro
One new thing I did for the 12.6.1 install was to empty out all AAX plugs (to their own folder) Sync App Manager then install the HD Driver from App Manager. No using the HD Driver download from my account! then restart. Launch Pro Tools to finish installing...close>Add back all my plug-ins skipping the stock plugs. Launch App Manager re-sync to check all is up to date.
(Should be)>Clear all caches from App Manager. then Uninstall app manage (Keep the uninstaller)
Old 12-02-2016, 01:03 PM
I appreciate the suggestions guys. Didn't realize I could install multiple versions on the same system. Might just end up reinstalling 12.4 alongside 12.6.
But I tried emptying out the AAX plugin folder and stopping the App Manager from loading on boot and that didn't solve it. So I went ahead and performed a full manual uninstall and reinstall of 12.6 but the result was the same. Makes me wonder if it's an OSX issue?
Alas, at least it does eventually load. Once again I greatly appreciate the suggestions.
Best,
-Patrick
Old 12-02-2016, 01:50 PM
fourthtunz fourthtunz is offline
Best,
-Patrick
Maybe try updgrading the OS to Sierra? I haven't used it much but 12.6.1 seems to work ok with the latest version of Sierra..
Old 12-05-2016, 10:38 AM
Problem solved. Apparently the new 12.6.1 HD driver only supports Yosemite 10.10 and up, I'm on 10.9. So I uninstalled it and installed the 12.6.0 legacy HD Driver and now Pro Tools is launching in under 10 seconds.
Thanks again for helping me troubleshoot.
-Patrick
Old 10-18-2019, 06:26 AM
cplaza cplaza is offline
Those of you in the Mac world are not alone. Experiencing the same or very similar problems on Windows 10
PT 12.5 taking a long time to open Blackers Pro Tools 12 5 04-05-2016 09:16 AM
Files taking a LONG time to open jameshbotha 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 04-30-2010 08:51 PM
Projects taking a long time to open zakco Pro Tools TDM Systems (Mac) 0 02-07-2008 02:20 PM
New HD3 taking a long time to open old sessions Loose Nutt Pro Tools TDM Systems (Mac) 2 11-30-2004 12:10 PM
Pro Tools startup taking a long time jeronimo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 07-06-2001 11:38 AM
