Old 01-18-2018, 09:33 AM
[email protected] pqlior@mac.com is offline
Default 9093 all day!
Had a super stable setup going on for a few weeks... Printed a pass last night.
This morning- 9093 in abundance. What?!
How are things changing constantly??
Lior
HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 *
iPad Air/Avid control * EuCon 18.3.0.217 *
Old 01-18-2018, 09:53 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: 9093 all day!
PT Prefs trash AAE, PT 12.8.3,
***remove AVID Application Manager when synced/finished
Type of boot drive, type of work drive and how full (50% < >)?
What was the last software change?
Old 01-18-2018, 10:11 AM
For me, disconnecting the internet solves 98% of -9093(I still have a wifi router connected to use my Artist Mix and iPad with the PT CONTROL app).
Old 01-18-2018, 10:57 AM
Internet disconnected. Errors non stop with NOTHING changed from last night.
All drives are SSD with PLENTY of space on them. Application manager get uninstalled THE SECOND PT installs it. Now getting 9172 as well.
(side note- depending on the iPad you have, you can run it with ethernet so no wifi needed-
https://www.lifewire.com/connect-ipa...t-port-1994242 )
Lior
Old 01-18-2018, 10:59 AM
john1192 john1192 is offline
hi dave, do you think it is your LAN or the connection to the outside world that is doing this ??
have you tried an ADHOC network for the PT Control App .. this might get you off the internet but keep you on you lan ..
i have thought about another option .. if you have Dual Band Routers .. keep the 5.6ghz portion off the net and just use the 3.2ghz for that .. so when you connect to 5.6ghz side you are only on the LAN ... now i am not a network Guru - so maybe someone can verify this ..
i might be able to test this out later today .. everything here is 3.2 except for PT Control and if i want my laptop on a separate band ..
just some thoughts to help you guys out a bit ..
cheers john
Macmini M1 8/512 -OS 12.3.1 and PT2022.4
Logic Pro X 10.7.4
RME BabyFace Pro
Macbook Pro july 2014 2.5ghz 16gb ram 512gb SSD - OS11.6.5 - PT 2021.3
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-18-2018, 01:49 PM
cheers john
Hey John, sadly, my networking skills are way beneath all my other skills, AND my network setup is a tad convoluted(and here is everything I am qualified to describe). Cable comes in the building and hits Comcast Modem and Comcast Phone box. That network port feeds an enterprise-level Ethernet switch. The switch feeds(via Cat5e) 3 rooms(wired connections) and a wifi router in the office(general wifi for client use). The cable going to the control room hits a dual-band wifi router. This router serves to connect an Artist Mix, 2 computers(my PT rig and my mastering rig) and handles an iPad running the Control app. With the cable from the main switch connected, I get constant -9093 errors and transport stops. Viewing Task Manager>Network shows network spikes every 30 seconds(fairly consistently) and USUALLY shows a spike at the same time PT stops and throws the error. Disconnect from the main switch and I can go all day and have maybe a single -9093
Old 01-18-2018, 02:46 PM
See if you can get someone to upgrade that cat5 to cat 6. And try having them change the wifi channels.
Jack
QAPLA!
Old 01-18-2018, 02:57 PM
ok, thx for that info .. since it seems to be ONLY the Wi-Fi portion .. your two rigs that are suffering .. "And try having them change the wifi channels" this is a good idea ..
and i assume you have tried connecting via Wired, without using Wi-Fi - maybe that was in this or another thread .. please excuse me if i bring something up that has been tried ..
Logic Pro X 10.7.4
RME BabyFace Pro
Logic Pro X 10.7.4
RME BabyFace Pro
Old 01-18-2018, 03:13 PM
Seeing the word 'Comcast' reminded me of something we dealt with at home when we had them as our ISP and entertainment provider. The shielding on their systems is pathetic. At first I thought it was my ham radio gear getting into the system but it happened even with all my radios shut down and disconnected. Local fire & police radios were getting into the system, not to mention the radios the local taxis were using. Got rid of Comcast and Verizon has been clean as a whistle.
Jack
QAPLA!
Old 01-18-2018, 03:29 PM
DetroitT's Avatar
SSD's with trim enabled? (Some don't need this). I use Samsung EVO's and Disk Sensei)
Error -9093 vudoo Pro Tools HDX & HD Native Systems (Mac) 24 08-09-2019 04:47 AM
DAE error -9093 mikep07 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 05-04-2008 03:37 PM
9093 !!!!!!!! - IRQ? hitwriter 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 01-21-2005 08:24 PM
HELP -9093 Matt W 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 3 02-20-2001 08:21 AM
dma and 9093 reeve oliver 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 07-27-2000 08:07 PM
