moving midi notes
Just want to say sorry before I ask this really basic question.
I have imported my midi data but it has ended up on the wrong note how do I move the data to the note above in Cubase I would just highlight it and move it up one not but I can’t seem to find the control to do it Why is the Midi in Pro tools hard to use (maybe its not) could someone be kind enough to give me a few pointers. Thanks |
Re: moving midi notes
Instead of viewing NOTES in the midi track, switch to REGIONS view in the track. From there, you can highlight what notes you want to move over and then drag and drop.
PS... I think its called REGIONS, maybe BLOCKS.
PTLE 7 Digi002R, Intel P4 HT 3.0GHZ w/ 865 Chipset, 2GB (4x512)RAM PC3200, WinXP Home SP2, 160GB 7,200rpm, 74GB 10,000rpm |
or you can shift click on the piano roll of the "offending" notes, which selects all the notes on that line and then you can drag them up or down to where it should be.
There is a few ways to do this, the easiest being to put the cursor on the track (in notes view) hit CNTRL + A and then select the grabber and just move the midi info to the correct posistion, or you can choose to transpose it to the correct spot as well, if you keep it in grid mode it should be very simple.
Sign up for all things....AWESOME! Kris May the music move you |
Moving Controller Data with Midi notes | Swar | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 10-29-2009 09:38 PM |
Moving midi notes | Tim Rector | MIDI | 3 | 12-01-2007 04:19 PM |
Moving Very Short MIDI notes | timdiggle | Tips & Tricks | 8 | 04-03-2006 08:31 PM |
PT7 Moving Midi events to different notes | bakerja | Pro Tools M-Powered (Win) | 4 | 01-28-2006 06:38 AM |
Moving MIDI Notes | Dog BBQ | Pro Tools TDM Systems (Mac) | 3 | 10-12-2000 06:02 AM |
