Old 04-11-2013, 07:48 PM
chuck goodwin chuck goodwin is offline
Default Delay compensation with backline delay
I love being able to backline delay individual channels on the profile venue, keeping the vocals undelayed and the drums and amps delayed. However there seems to be no easy way to see how much processing delay is already on the signal paths. I would like to subtract that processing delay from the actual backline delays.
What is the analog input to analog output processing delay without plugins engaged? (the specs say "less than 2.8ms" so is that 2.8ms or does it vary?)
Do I have to manually calculate the total plugin delay? (2 samples per plugin plus plugin(s) delay plus 3 samples) Or is there a way to see that automatically?
Old 04-12-2013, 05:50 AM
Dsturzy Dsturzy is offline
Default Re: Delay compensation with backline delay
You could use your FFT program of choice... smaart, systune, etc.
Old 04-12-2013, 03:13 PM
Mike Z's Avatar
Mike Z Mike Z is offline
Hi Chuck,
There is a way to see the total plug-in delay for inserts on a channel. In the Inputs or Outputs page, right-click anywhere in the Inserts section to reveal the Total Process Delay.
-Mike
Avid Live Sound Support
Old 08-09-2013, 07:54 AM
sully1time sully1time is offline
If you want to delay to the backline then i would delay the whole PA to the Backline, by doing it to individual channels and not the whole thing you are introducing a ton of phase smear into your mix, remember the drums get into every mic on stage, even if just a tiny bit it will cause phase issues.
I delay my whole PA between 10 and 25ms all the time and no one ever notices on stage
Pro Tools 9 Delay and Delay Compensation on Aux Tracks and Bussing CNSound macOS 1 01-27-2012 11:10 AM
Delay compensation- choice of 'Medium delay'? dtmprod Pro Tools TDM Systems (Mac) 2 05-05-2010 11:00 PM
Delay Compensation Tonewrek 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 08-09-2006 04:08 AM
Delay Compensation - Delay Monitoring when REC Howardk Pro Tools TDM Systems (Mac) 2 06-18-2006 08:59 PM
Delay Compensation Spin001 Tips & Tricks 6 05-21-2006 06:48 PM
