Converting to and Sending WAV Files??
How would I get a 28 track session to WAV files, either for FTP send or FedEx CD? Person on the other end doesn't have any PT but his recording system will certainly take WAV files. Thanks.
Re: Converting to and Sending WAV Files??
I assume you are running a MAC(if you are on a PC, you should already be in WAV format)? Open your session and consolidate all tracks so they are single continuous files>select all unused regions and REMOVE them (not delete)>save session copy(selecting WAV)and check the box for all audio files(sorry its not in front of me so I am working from memory). Now go find that new session folder and open the folder to see the sub-folder "audio files". This folder should have all the audio and each file will be a complete track. Send this folder to your pal. It may be large so you may need to use something like www.yousendit.com. When your pal downloads the folder, he should be able to simply inport each audio file to a track in whatever software he runs. Let him know the sample rate and bit depth so he can create his session at the same values which will save a conversion step. Of course if you are running an old version of PT that records SD-II files, this may not work.
Albee, once again thank you VERY much for your info
Converting Vision files to ProTools or general midi files!!! | Paata | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 04-17-2008 01:11 PM |
sending session files | hitwriter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 09-14-2005 01:25 PM |
sending files on the net | dosbad | Tips & Tricks | 1 | 01-01-2005 02:29 PM |
sending files through the internet | Orange Worker | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-02-2004 10:45 AM |
Sending PT files over Net... | PacMan | Tips & Tricks | 10 | 10-10-2000 08:05 PM |
