Transpose Shortcut Broken in 2018.7
Anyone else getting this bug on PC?
Shift + Arrow Up is not working for me, however Shift + Arrow Down still transposes down. Just want to check here before I submit bug report. (Tried search already) Windows 10 PT 2018.7 32 gb ram Core i7 etc... etc... |
Re: Transpose Shortcut Broken in 2018.7
actually scratch that-- a whole MESS of transpose bugs
sometimes Shift + Arrow Up works, but it goes two octaves instead of one and doesn't take all notes with it... even the Transpose dialog box has this issue (when set to one it transposes two octaves) Someone please let me know if you can replicate this issue! |
- Intel 14900K/NzXt Kraken Elite/64GB Kingston DDR5 6000 mhz (32x2)/ Asus Pro Art Z790/Asus 4090/Win 11 Pro 23H2/UAD Apollo 8 x2 w TBolt 3 card u/g/UAD Twin X. |
thanks for checking, still curious to see if it happens on another Windows machine.
i actually did submit a bug report anyway out of impatience haha |
This happened to me, ctrl+up would transpose 6ths and other nonsense like that.
What TNM said, trashing prefs and the usual fixed it.
Dell XPS 8700. Intel Core i7-4770 CPU @ 3.40GHz. RAM: 16GB. Windows 10 Home x64. NVIDIA GeForce GTX 645. NI Komplete Audio 6. Pro Tools Software 2019 amagrasmusic.com |
i've actually never had to do this before though I've seen it mentioned... what will it get rid of, i.e., what will I have to set up all over if anything? just so I know if it's worth doing right while i'm in the middle of a project or better to just put up with it for the next 24-36 hours. |
Get guitardom's Trasher. Close PT, then using Trasher, backup Preferences, Delete Preferences and Databases, close Trasher, then empty the Recycle Bin, reboot, restore Preferences with Trasher and open PT. First thing I do anytime PT starts to act up. Pete Gates has a similar app for Mac.
I ordered it from his site this morning... hasn't sent it yet though? do you know how he usually takes? |
ok well actually when i restarted my computer this morning the problem went away.
****** computers are weird. |
it's just this, right? https://www.youtube.com/watch?v=ltDYmfky-EI
i wrote my explanation about the bug in the youtube video description but basically the solution is either use shift and up/down arrow keys to transpose and don't open the transpose dialog OR use the transpose dialog exclusively and no arrow keys. if you try to go back and forth between the two different ways to transpose, you will have trouble. |
Latch Record broken again in 2018.7 | SomeOtherGuy | Pro Tools 2019 | 20 | 09-03-2020 08:26 AM |
Retrospective Record broken in 2018.4 | Hanswurstlsepp | Pro Tools 2018 | 1 | 04-23-2018 08:46 AM |
Change Nudge Value shortcut broken? | Kobra | Pro Tools 9 | 4 | 06-19-2013 08:14 AM |
Track Height Shortcut broken | cowrange | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 03-04-2012 11:01 AM |
Shortcut for assigning inputs broken?? | Fireball71 | Tips & Tricks | 1 | 02-27-2006 09:30 PM |
