Time Factory II 25fps to 24fps PROBLEM
Hi everyone
I need to create the 24fps master for the DCP release of a 25fps project. I have done the audio speed change in Time Factory II, stem by stem to avoid artifacts as much as possible, and then re-recorded the 24fps mix from the time-expanded stems in Pro Tools. Here is where I encounter my problem - the new 24fps mix does not sync up with the 24fps picture. I have done a plain-old SRC (with subsequent pitch change) using the import option in Pro Tools, and the 24fps mix from the Time Factory stems is about 10 seconds shorter than the Pro Tools SRC. Am I correct in thinking that as the 24fps mix needs to run 4% slower than the 25fps original, the percentage change in Time Factory II is 104.00%? I think my problem is coming from there, although on the face of it this should work? Thanks in advance for any tips/advice. |
Re: Time Factory II 25fps to 24fps PROBLEM
The math is here: 25 : 24 = 1.0416666. Thus 0.16666% makes the difference you are talking about. So enter the value in Length (Percent) window 104.1666 and you'll be fine. Chers
Michael Goorevich Sound Designer / mixer www.goorevich.com PT HD⎪N v2024.3 Ultimate ● macOS Ventura 13.6.3 MacPro 7.1 (2019) 3.2GHz Intel Xeon W 16-Core ● 96 GB RAM MTRX Studio + DADman 5.7.0.1 + MOM ● Sync HD ● AJA Kona LHi referenced by AJA GEN10 ● D-Command ES24 |
SZE, just go to TF Advanced Options panel and choose the in and out frame rates, no need to calculate.
Thank you both so much for the help!
24fps to 25fps with Prosoniq Time Factory - help needed | jmattchan | Post - Surround - Video | 6 | 05-14-2015 06:24 AM |
Using 25fps to 24fps then the converted 24fps to new 25fps. Stay with me on this! | abes | Post - Surround - Video | 2 | 03-01-2013 09:36 AM |
Please be gentle: 24fps to 25fps SRC? | JanuS | Post - Surround - Video | 6 | 09-27-2007 12:58 PM |
25fps - 24fps - Help! | paulspurrier | Post - Surround - Video | 1 | 10-03-2004 02:36 PM |
25fps into 24fps? | Xabi | Post - Surround - Video | 1 | 11-04-2002 03:10 PM |
