Closed Thread
  #31
Old 02-14-2020, 05:26 PM
MikeReganNoise MikeReganNoise is offline
Default Re: Clips suddenly referencing wrong audio
Question, are your systems on 2019.12 and Mac OS 10.12.6?
  #32
Old 02-15-2020, 01:44 PM
capt kirk capt kirk is offline
This is what I dont understand...how can you go from useful, versions, to SHOWSTOPPER problems like this??? who is being allowed to modify code like that, without even knowing the basics or testing it? With software this mature, theres virtually no chance this ocurs, unless they let someone loose in the process who understands virtually NOTHING about the critical nature of these files, and expense involved. Why is Avid doing this? to save 120 bux a day?!?!?!?!? THIS IS WHY I'LL NEVER CHANGE VERSIONS, i CANNOT TRUST that they wont throw some imbecile from grade school at the code and let a version loose that wipes my entire drive......what would i do? how would they compensate me ?
www.kfaudio.ca
  #33
Old 02-17-2020, 06:34 AM
StefB's Avatar
StefB StefB is offline
2019.12 on Mojave (10.14)
Mac 16 Core 7,1 -Os 10.15.7 - 96 gb Ram - Pro Tools 2022.6 Ultimate in 5 suites - MTRX Studio -S6 26-5-D - Sync HD - Video Satelite (Symphony 2022.5, AJA Kona 3g) Pro Protools 2022.6 Vanilla in 21 x Recording and Edit suites. Mac 6,1 Mac Mini, Mac Mini M1, Mac Studio Pro, Mac Studio Max
Mediacomposer 2021.12 on AJA Kona 3g / XT I/O x 3 suites. Multiple Avid S1, S3 & Docks
  #34
Old 02-17-2020, 08:07 AM
ubxf ubxf is offline
2019.12 on Mojave (10.14) here too. Created a very simple session in 2019.12
with only one stereo file imported then split in dual mono. I used only the left side, did some edits and saved. When i reopened the session a day later the edits were there but the audio referenced was the right even though the region said .L
  #35
Old 02-22-2020, 04:14 AM
Arno Peeters's Avatar
Arno Peeters Arno Peeters is offline
Absolutely no reason to be lazy, but I can't find the time to read all comments: too darn busy making my deadlines.
But what I noticed since the last update is disappearing audio: just random files missing or e.g. manually moved used files to the audio files folder (after session close), to be gone, next time I open the session!
Is that maybe part of the same issues described here?
Arno Peeters
Tape TV Productions
  #36
Old 02-22-2020, 05:57 AM
Tim R. Tim R. is offline
I don't think it's the same thing. The issue here is (apparently) imported tracks (using import session data) with clips that reference the wrong audio after closing and reopening the session. The error reported is: "Some clips had invalid bounds and were adjusted or deleted" when openig your session. Notice Admin post at top of page for workaround details.
Tim Reisig
Main System: Pro Tools Ultimate 23.12, HD Native TB, HD OMNI, S3/Artist Transport/Eucontrol 22.20, Apogee Rosetta 800 w/XHD card, Avid 96 I/O
Mac OS 13.2.1, 2018 Mac Mini 3Ghz i5, 32Gig RAM
System 2: Pro Tools 23.9 (no Hardware), Mac OS 13.2.1, MBP (Macbook Air M2, 2022 24Gig Ram)
  #37
Old 02-22-2020, 06:02 AM
Thanks: much appreciated!
Arno Peeters
Tape TV Productions
  #38
Old 02-22-2020, 11:20 AM
Hey Arno,
This sounds like it could be related to what I've experienced here:
http://duc.avid.com/showthread.php?t=405902
  #39
Old 02-23-2020, 08:56 AM
Hey Arno,
That's seems like it... Will have to investigate more. Thanks for pointing that out!
Arno Peeters
Tape TV Productions
  #40
Old 02-27-2020, 12:42 PM
Cheesehead Cheesehead is offline
Just had this bug happen to me with clients in the room, on thankfully a quite small feature.
I worked on the session last night and everything was fine, opened it this morning and regions are showing seemingly completely random audio.
I'm running 2019.10 and the problems originated in a session sent to me by my SFX editor, I'm not sure what version she's running, I'll chase and find out.
I basically had to re-import her work and rebuild the session with the clients in the room, nightmare!
Now I'm terrified to close the session after what I've read in these threads, all the work might screw up again.
This is the worst bug for a considerable time in PT, I'm opening a case!
Come on Avid get this fixed asap!!
Mac Pro 7,1 16 core, OSX 12.7.3, HD-Native TB, Trinnov MC, MTRX Studio, 2xRME ADA-4, Sync HD, AJA IO XT, Avid Dock, Avid S1, PT Control, Soundflow, PT 2023.12
Closed Thread
Media Composer AAF clips referencing incorrect section of media David McCarthy Post - Surround - Video 13 03-30-2017 12:11 AM
Wrong "auto-rating" of clips during loop recording joachim Pro Tools 11 5 02-10-2015 11:58 PM
wrong "Auto"-Rating of Clips, loop rec 10.3.7 HD Mac/Win joachim Pro Tools 10 14 05-23-2014 09:45 PM
fades referencing wrong audio files fractal_harmonics Pro Tools TDM Systems (Mac) 2 09-16-2007 04:55 AM
cd referencing a PT mix Dr. J Tips & Tricks 9 03-23-2001 09:40 PM
