AAE-9173 Protools 11.3 Update Cant Bounce/Mix Down
please help, after I downloaded the protools 11 11.3 update I started getting frozen moments hanging when shut down just hanging. but worst of all I cant finish a a BOUNCE/Mix down. at any point during Bounce protools stops & I get this AAE-9173 ! this never happened before update 11.3 is there a patch coming out or some help please? I use w/7 64bit on an hp 3.0hz desktop 24GB of ram ive done 48 track bounces prior pc at 24% usage. I was told by Avid helpdesk to eliminate the prior 11.2.2 update so I cant step back not that I want to but this is terrible. my machine ran great prior. have a nice day
kind regards john c |
Re: AAE-9173 Protools 11.3 Update Cant Bounce/Mix Down
I'm having the same problem. Gonna try and go back to 11.1 and try then. This is a seriously bad bug to have though. Y'all need to fix this crap. Unacceptable for such an expensive program
I agree, now with this pt 12 I don't need to do that international jam I fortunately have band buddies. but waiting on an update that may never come I feel like a fish out of water. pt11 is my water
PT's 11.3.1 is latest.
More info on your OS and other setups may get you a better specific answer.
(Help us Help You)<<<click here Profile-System Tracks: https://www.n1m.com/datatunesdetroit Apple Music https://music.apple.com/us/search?term=DatatunesDetroit |
This is a known and reported bug in PT11 that still hasn't been fixed properly in PT12! (see http://protools.ideascale.com/a/dtd/...er/149822-3779. It or may not help if you "vote" to get it fixed - you'll have to register for an account to do so (http://duc.avid.com/showpost.php?p=2265477&postcount=33)!, but its pretty easy to do. See my comments for workarounds.
Strange, as I am currently running 11.3.1 under Win 7 as is the OP and have never had this sort of problem.
Dell Precision 490 Workstation, dual 4 core 5355 Xeon, 16gb Samsung DDR2 ECC Ram - Windows 7 Ultimate - Nvidia GTX 650 - 3 x Internal WD Blacks - PT 2018.3 - Digi 002R - Original Mackie HUI - 3 screens - JBL Monitoring. Dell XPS 8700 i7-4790 - 24gb RAM - Windows 10 - Nvidia GTX 1060 6GB with Studio driver 546.01 - 2 x Internal Samsung 860 EVO SSDs, and MSATA card - Davinci Resolve Studio 18.6.4 - 3 screens - Blackmagic Speed Editor - MK1 Presonus Faderport - Canon C100 mk2 - Atomos Ninja 2 - Zoom H2n |
That's likely because you use lower sample rates, fewer tracks, and/or larger buffer sizes. All of which are easier on the software. See http://duc.avid.com/showthread.php?t=368271 for details.
Just done three offline bounces of the Kelly Malone demo. One at 24/48, one at 24/96, and one at 32 float/96. All were done with a 64 bit buffer. No problems or errors. The offline bounce speeds were 7.2, 6.4, and 5.6 respectively.
I would also add that if the OP did not do a clean install but just ran the 11.3.1 installer, Windows will just update parts of the existing PT installation, a sure fire cause of problems.
Like I said, you need to get the offline bounce speeds down to <3X. Try a slower hard drive (an old USB 1.0?), NAS, and/or add more tracks (to 10?) and record while monitoring on all of them. I'm starting to think that the problem is caused by PT communication issues with the interface driver - so it would be interesting to see if you PCI interface works better than USB interfaces. Thanks for the feedback!
p.s. I uninstalled 11 before installing 12 on the desktop PC I did the tests on. Quote:
Why would he purposefully use unsupported storage in an attempt to gut bounce speeds? And why do you think bounce speeds to an unsupported USB 1.0 hard drive is any reflection of the audio interface?
On top of that, keep in mind offline bounce does not use the interface driver. It all happens internally.
Pro Tools HD 12.4, Pro Tools "Vanilla" 12.4, Artist Transport, 2x Artist Mix Studio Blue: RME UCX, Win7 Pro, i7 960, 16GB || Studio Green: RME Babyface, Win10, i7 7700HQ, 16GB |
AAE -9173 Issues | deadshot | Pro Tools 11 | 145 | 07-08-2016 09:24 AM |
Cpu 9173 | mistermackum | Pro Tools 11 | 1 | 12-20-2014 02:20 AM |
AAE-9173 follow up | xylie6 | Pro Tools 11 | 3 | 12-10-2014 12:02 PM |
PT 11 Clearly Not An AAE 9173 Error | rgconrad1 | Pro Tools 11 | 3 | 09-29-2014 11:56 PM |
Aae-9173 | txrx | Pro Tools 11 | 5 | 12-28-2013 04:34 PM |
