Help with 5.1 surround sound bounces
Hi I have the 3rd gen Pro Box w/PT 11. Something dealer stated I can use 5 output speaker or so to do Surround Sound Bounces or mix downs. I can only get the Surround Sound effect from the keyboards combonation sound. What is the point of having 5 or 6 speaker out put jacks on the M-Audio Pro Box if it can not do a surround sound bounce? is it possible to connect the 6 outputs 1/4" inch from my Korgsynth to the inputs of my Pro box & get a ss 5.1 mix down? I also heard that Avid offers a HDD or HDX Bundle that has the surround sound 7.1/7.2 Bounce? Thanks for any help you can provide.
Re: Help with 5.1 surround sound bounces
Bounces are independent of physical outputs. Bouncing happens inside the computer. Also note that you are limited by the type of material your software can output - for example, PT can't do surround but PTHD and CPTK can.
The advantage to having multiple outputs (aside from playing back surround material) is having multiple sets of monitors, using send/return effects, etc. |
ah I see. I also use a external Mackie mixer to direct the L'R inputs to my Mbox Pro. its a non usb mixer but helps me from unplugging 1/4" inch inputs all night. so is what your saying. if i bring the content in & the content (Korg combo sound) is formatted as 5.1 & I use the sends on the Mixer for that Keyboard into the Pro Box 12, 34 Inputs & I add additional monitors I would be able to hear the 5.1/7.1 surround sound sounds as well as record them & the finished bounce would be in surround sound? what speaker system/monitors would I get. would I need a subwoofer. I have 2 alesis M1's already. as i said some combonation sounds in My Korgs after I bounce final mix & play back the bounce on my home ss theater system the ss speakers activate on some sounds. Thanks ver much. I hope I understand you correctly. I just did not get why the Avid 3rd gen Probox had 5 outputs for 5 speakers for surround sound if it/ well protools 11 did not allow me to do a ss bounce/Mixdown Thanks again good day
jc |
kind regards jc |
Sounds like you have base line 11 not 11HD
To make 5.0 or 5.1 files you need to be-able to make 5.0/5.1 paths, that is only posable in 11 with the HD license.
... "Fly High Freeee click psst tic tic tic click Bird Yeah!" - dave911 Thank you, Craig |
The reason for the discrepancy is that the Mbox Pro was introduced back when Protools 8 was out. Through Protools 8, 9, and 10, you could use the surround features of the software by using the Complete Production Toolkit. It was only a recent decision to discontinue the Toolkit. Your dealer should have informed you of this.
Thank you all very much. so I'd have to upgrade to pt HD 10.8 then to HDX & even if I did my 3rd gen MBox Pro would have to go as well. so im looking at 4-6 Grand maybe more for the ability to do a surround sound bounce or /mix down. Since my Korg has L/R outputs as well as a 1-4 outputs & some combonation sounds are native surround sound. would I be able to record that combonation sound using the 1-4 out puts on Korg going into the 12/3,4 inputs of the avid mbox pro? Thanks so much. I am chasing for right now an unafortable setup. good day
kind regards jc |
Kind regards jc |
jc |
Why don't my mastered bounces sound loud? | swansong | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 13 | 03-19-2008 08:41 PM |
Bounces sound mega-distorted through mac or iTunes | davetron5000 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 9 | 05-24-2006 01:52 PM |
Surround sound other than Wave Surround? | Kryst | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 04-28-2006 06:31 AM |
surround bounces to avid?!?! | AdamFrick | Post - Surround - Video | 3 | 05-06-2002 07:24 AM |
surround bounces to avid | AdamFrick | Pro Tools TDM Systems (Mac) | 0 | 05-01-2002 06:59 PM |
