Go Back   Avid Pro Audio Community > Pro Tools Hardware > Pro Tools | Carbon
Old 02-24-2021, 11:33 PM
Megalobass Megalobass is offline
Default Output Impedance
I did some research but I didn't find any info:
I would like to know the output impedance to check if it will work well with my monitoring system.
Same thing for the headphone output.
Thanks for your help!
Best
Bertrand
Old 02-25-2021, 08:59 AM
Kyle Splittgerber's Avatar
Kyle Splittgerber Kyle Splittgerber is offline
Default Re: Output Impedance
Hi Bertrand,
Line Outputs & Monitor Outputs are 100 ohm balanced (50 ohm per leg). Headphone outputs are 100 mW into 300 ohm; 200 mW into 32 ohm.
Kyle Splittgerber
Senior Principal Product Designer
Berkeley, CA
Old 02-26-2021, 07:58 AM
dominicperry dominicperry is offline
Those really aren't output impedances...........
Old 02-26-2021, 10:44 AM
Thanks for pointing that out. Headphone outputs are 10 ohm.
Kyle Splittgerber
Berkeley, CA
Old 03-02-2021, 11:52 PM
Hi Kyle,
Thank you so much for your feedback!
Best
Bertrand
Old 03-03-2021, 09:43 AM
Originally Posted by megalobass View Post
hi kyle,
thank you so much for your feedback!
Best
bertrand
Kyle Splittgerber
Berkeley, CA
11R headphone output impedance musicman691 Eleven Rack 0 01-19-2021 11:29 AM
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs MR290378 Eleven Rack 12 11-29-2011 05:10 PM
003 output impedance conversion Marvin the android 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 10-15-2010 07:50 AM
Reflected Impedance & Highest Output Level, 192? audiomark Pro Tools TDM Systems (Mac) 1 04-07-2006 01:23 AM
882/20 Output Impedance??? TAGS Pro Tools TDM Systems (Mac) 2 08-13-2004 12:52 PM
