Difference between accel card and process card?
Has anyone done any tests to see how much more power an accel card has over a process card?
Re: Difference between accel card and process card?
I think Accel has more DSP chips than Process.. Accel 9 chips, and Process 7 chips...
Mix Stage 1 PT HDX Ultimate 2022.12 D-Control HD I/O Hackintosh i9 12900K 32 Gb RAM OSX 12.6.7 Mix Stage 2 PT HDX2 Ultimate 2023.6 S6 MTRX I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 Mix Stage 3 PT HDX Ultimate 2023.6 D-Command HD I/O Hackintosh i7 8700K 32 Gb RAM OSX 12.6.7 ADR PT MBox Studio Ultimate 2023 Mac Mini M1 8 Gb RAM OSX 13.4.1 Edit 1 PT HDN PCIe 2023.6 96 I/O Intel i7 6700K 32 Gb RAM.OS Windows 10 Estúdio JLS Facilidades Sonoras São Paulo - Brazil |
Accel plugs will only run on a card with Accel chips. Digi has a white paper out there that discusses the differences between the cards.
Scott Formerly Hobo Wan Kenobi Core 2 Specs Page ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88 |
They both have 9 chips. Process cards have 9 presto chips the accel has 3 presto chips. 4 accel chips (321 chips) with sram and 2 accel chips (321 chips) without ram. using accel maximized plugs can give you almost double the processing power Chris
Also som plugs won't run on Process cards(definitely @ certain sample rates) &/so ur plug count on that card will be a bit shabby...
& Chris u learned me som'n because I thought Process cards only had 7chips...
This is the White paper I was thinking of. It may have some useful info for you or not.
tks for the infos!
i wanted to resurrect thins thread because i cant find much info on the difference in power b/w hd process cards and accel. (pcix)
most references are about the number of chips or types of chips on each card or comments on more voice counts but haven't seen any sort of benchmark or comments on ex process card users who now can can open or do X amounts of things better w accel. how much more in plugin DSP are we talking about? any % or real life application that i could kinda tell the difference. examples etc? there must be some sort of good marketing info that Digi provided to persuade folks into accel systems cards back in PCIx only times... later in PCIe there was (is) no choice. |
As i said in post 4. using accel maximized plugs can give almost double. if the plugs haven't been coded to take advantage of the accel chips then you'll get the same! it totally depends on which plugins!! Chris
Recently I was exposed to the philosophy that certain reverbs run better or more efficiently on Process cards than they do on Accel cards. The person offering this viewpoint did not know the basis of the claim, but he felt it had come on good authority. At first blush, it would not appear to make sense.
Can anyone offer how this could be the case? John Caldwell
Pro Tools 2018.4 HDX, 192 and Lucid I/O 5,1 MacPro 12 Core; OSX 10.12.6 |
Process Card Question... Accel vs non Accel | gsilbers | Pro Tools TDM Systems (Mac) | 13 | 05-22-2013 01:51 PM |
What are the differences between a process card and an accel card? | mboxpro | Pro Tools TDM Systems (Mac) | 7 | 10-15-2008 05:44 AM |
HD Process card vs. Accel card | Eric Seaberg | Pro Tools TDM Systems (Mac) | 1 | 09-10-2004 01:29 PM |
Accel card with HD Process card | Jazzbass56 | Pro Tools TDM Systems (Mac) | 7 | 07-22-2004 11:54 PM |
Process and Accel card | Zeljko | General Discussion | 1 | 09-15-2003 09:19 AM |
