Pro Tools 9 Won't Record Sound
Hello,
I have a 1220i mixer set up with 2 microphones. In Pro Tools, I set up two mono tracks to assign to each microphone and neither one will out pick sound. Everything is correct with the hardware and connections since I called the manufacturer customer support to confirm hardware operation. However, Pro Tools 9 will not pick up sound. I click the smaller record buttons on each track, and the large button, and it suddenly illuminates the stop button and says "recording pause". If you have any ideas on how to configure the software to record sound, please let me know. Thank you! |
Re: Pro Tools 9 Won't Record Sound
Wow - I would say search the site for "how to trash prefs"
And then try it again - what's ur playback engine ?
When you say, "and the large button". What button is that? Can you hear audio from Pro Tools? How are you interfacing the audio board? Have you selected the audio board as your audio engine? What audio engine have you selected? Are you on a Mac or PC? The more info you give, the faster a solution will be found.
Park The Transfer Lab at Video Park Analog tape to Pro Tools transfers, 1/4"-2" http://www.videopark.com MacPro 6 core 3.33 GHz, OS 10.12.1, 8 GB RAM, PT12.6.1, Focusrite Saffire Pro 40, PreSonus DigiMax, MC Control V3.5, dual displays, Neumann U-47, Tab V76 mic pre, RCA 44BX and 77DX, MacBook Pro 9,1, 2.3 Mhz, i7, CBS Labs Audimax and Volumax. Ampex 440B half-track and four-track, 351 tube full-track mono, MM-1100 16-track. |
hello
if control is down, control command space prepare record and...prepare playback (something like auto-cue i forget the word) In this case stop light and play is blinking abblabla |
Maybe you accidentally clicked on Wait for Midi Note? F11 toggles that feature
You also should go into preferences and set record allocation to 10 minutes(or as long as you really need).
Why Can't I Get Pro Tools To Sound Like A Record? Need Help Bad! | BaRaq' | Pro Tools TDM Systems (Mac) | 50 | 01-02-2017 10:00 PM |
Pro Tools recognizes sound but won't record DI | BlastBoy | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 6 | 08-24-2010 11:54 AM |
How do I record sound from dvd? | sureno | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-16-2007 08:44 PM |
Why does it sound different after I record it? | roberts | Pro Tools TDM Systems (Mac) | 4 | 11-18-2005 10:41 PM |
Pop sound whenever i record | discostu | General Discussion | 3 | 07-19-2001 10:19 AM |
