Go Back   Avid Pro Audio Community > Pro Mixing > Pro Tools | S3
Old 05-10-2019, 12:36 AM
Jamie Mac Jamie Mac is offline
Default 2019.5 OLED not responding properly
Bottom row of OLED's are not properly updating when switching from PAN to EQ or AUX.
It requires multiple button presses to display the correct function. (function is correct however, when touching or turning the knob the correct values change)
Any one else have this issue?
Old 05-11-2019, 04:14 AM
pavoni pavoni is offline
Default Re: 2019.5 OLED not responding properly
Sounds very similar to the problem I just had http://duc.avid.com/showthread.php?t=404596
Old 05-12-2019, 02:43 PM
ha2dorff ha2dorff is offline
+1
Old 05-12-2019, 04:50 PM
mattrixx mattrixx is offline
The top row is not behaving as it should in some cases I am finding also.
For example, sometimes, when I click "inserts" for a particular track, the OLEDs won't update, but the green "In" buttons do.... Have to click "back" and try again to update.
Matt McKenzie-Smith
mattrixx.net
SourceConnect - mattrixx
AVID Collab user - mattrixx
Old 05-13-2019, 05:38 AM
ACECOM ACECOM is offline
Same here. (S3+Dock+Mojave).
Old 05-14-2019, 02:52 AM
@tention @tention is offline
It's broken
SOUND!
Old 05-14-2019, 08:59 AM
EddieJones's Avatar
Can I ask....if you touch the knobs when the OLED's are displaying the wrong thing...do they change to the right display ? (Just want to make sure we are seeing the same thing)
Old 05-14-2019, 09:43 AM
No, it's just strange. There seems to be a HUUUUGE delay when you touch someting. Sometimes the OLEDS will react, sometimes they won't.
On my system it feels as if the displays do not get the command to 'update' or 'refresh' at the correct rate. This also goes for volume readout when you move the faders.
As an example you mightl see the name of the track, then it will jump to -40 then it will stay there although the track is at minus infinite.
As this is rather annoying I hope for a quick fix.
SOUND!
Old 05-14-2019, 09:48 AM
EddieJones's Avatar
As an example you might see the name of the track, then it will jump to -40 then it will stay there although the track is at minus infinite.
OK, so this is not the OLED issue others are seeing (although you are probably seeing that too) It sounds like the system is bogging down. Can I ask you to uninstall using the 19.5 installer, check remove all Apps and remove all prefs, and then reinstall.
Old 05-14-2019, 10:17 AM
Eddie - you may be asking specifically about the S3 - but on my Artist Mix where the OLED labels don't update - changing a plugin parameter works correctly - and the label then seems to update to be correct.
OLED eq graph Macsearcher Pro Tools | S3 9 10-26-2018 02:02 PM
OLED brightness RogerPaolo Pro Tools | S3 20 08-02-2018 07:29 PM
Artist Mix - text on OLED is cut off at the top Bul Artist Series 2 10-20-2012 09:40 AM
mc mix second channel 's OLED missing ! klyg Artist Series 2 10-10-2011 10:14 AM
