Old 05-09-2013, 03:51 AM
Default Re: Shared folder error
Originally Posted by apt View Post
Tried a standard (non-admin) account type on both Mac and Windows, and folders are still shared to said user. I guess I'll just use the permission-tweaking procedure for now.
I have plenty of external hard drive estate, but I like keeping local copies in addition to external copies. Of course, I'm starting to get now that PT is designed differently from other DAWs in that it's explicitly intended to be run mostly externally, so that's just something that I may have to get used to.
Cheers.
If you want to keep a local copy as a backup (which would be the only reason to have another copy) keep it on an external drive separate from your session copy which is also on another external hard drive.
Yup you're going to have to get used to the way PT works. A lot of people make the mistake of thinking they can run and use PT like they would any other daw.
"Can't Create Pro Tools Shared Folder" Crash sonicksound Pro Tools 11 1 08-23-2013 10:22 AM
Pro Tools Shared Folder MichaelKhan Windows 0 10-15-2012 01:37 PM
Paragon NTFS for mac or HFS for windows - do I need it when using a shared folder? John_Toolbox Storage Subsystems 6 05-27-2012 05:46 PM
Shared Library Error PaintChipR 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-19-2005 10:07 AM
Shared library error ERIC S 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 06-02-2004 04:23 PM
